Thread: question about rev limiter
Results 1 to 18 of 18
  1. #1 question about rev limiter
    SE Level Member jersey jok3r's Avatar
    Northern New Jersey
    I just installed a 3.4 pulley, have an overkill tuned pcm for a 3.4 installed already, just wondering if the overkill pcms remove the rev limiter bc it hesistates and loses power at 105 mph.
    Ported Outlet/Inlet,3.4 pulley,ZZP PLOG, ZZP 3"DP,U bend delete, K&N CAI, ZZP wires,high-flow CAT, ZZP TB Spacer, Autolite iridium 104s,180tstat, OVERKILL PCM, Borla Cat Back system, Black Halo HIDS, Phantom autometer gauges
  2. #2 Re: question about rev limiter
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    if you were hitting the rev limiter it would bounce off of it and stating what rpms your at would help us figure that out
  3. #3 Re: question about rev limiter
    Northern New Jersey
    thats what it feels like its bouncing or sputtering rpms 4500 to 5000
  4. #4 Re: question about rev limiter
    Dec 2010
    Ohio
    that might just be all your car has because it shouldn't be doing that at 4500
  5. #5 Re: question about rev limiter
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
  6. #6 Re: question about rev limiter
    Does the check engine light flash at the same time?
    Do you have MSD coil packs?
    When were your wires and plugs last changed?
    What brands did you use?
    Why are you driving 105 anyway..lol
  7. #7 Re: question about rev limiter
    SE Level Member Wakeboy1337's Avatar
    Dec 2010
    Fort Pierce, Florida, United States
    Take a video?
  8. #8 Re: question about rev limiter
    Northern New Jersey
    I'm gonna get a video up this weekend, im using zzp wires and auto lite 104's just changed them in the winter
  9. #9 Re: question about rev limiter
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by jersey jok3r View Post
    Try using stock wires and see if it goes away, or don't drive faster than what your car will trap.
  10. #10 Re: question about rev limiter
    Dec 2010
    Ohio
    I've heared zzp wires blow
  11. #11 Re: question about rev limiter
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Well the way you ask this question is contradicting. Are you talking about rev limiter, or speed limiter? You mention both.
  12. #12 Re: question about rev limiter
    GTX Level Member crbquist's Avatar
    Massachusetts
    I have more or less the same setup as you and my car was doing the same thing. I'm telling you it is those crummy ZZP wires.. I changed my wires a few days ago and now all is well.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  13. #13 Re: question about rev limiter
    Jersey
    you need prj wires
    to bad u bought the pcm. Best tune is a custom one
    16' wrx sti- stock
  14. #14 Re: question about rev limiter
    Donating User Odi's Avatar
    Chicago South Suburbs
    stock wires are the best bang for the buck youll get. theyre fine even on heavily modded cars.
  15. #15 Re: question about rev limiter
    Pennsylvania
    Perhaps your throttlebody spacer is causing a vac leak. Also, what are your plugs gapped at? Also - yeah, never heard of a single person happy with ZZP wires.
  16. #16 Re: question about rev limiter
    Northern New Jersey
    so go back to stock wires or spend a little and get prj's?
  17. #17 Re: question about rev limiter
    Banned
    Jun 2011
    Bethel, CT
    my car did that before i had the speed limiter moved to 129mph
  18. #18 Re: question about rev limiter
    Pennsylvania
    Stock wires work great. On the other hand PRJ's come in colors. Performance will be the same.
  1. start my car and it goes to the rev limiter
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2010, 12:28 PM
  2. ECU speed limiter possible?
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2010, 09:52 PM
  3. Limiter question..
    By Ninjo in forum General Tech Discussion
    Last Post: 11-03-2008, 11:24 PM
  4. Speed limiter?
    By Randy_W in forum General Tech Discussion
    Last Post: 05-23-2008, 09:58 AM
  5. Speed limiter @110 WTF???
    By ABINOK in forum General Tech Discussion
    Last Post: 03-20-2008, 08:55 PM
