Finally its starting to come together here it is. The hood and spoiler will be different.
ZZP Short Block with L32 rods, JE 10:1 pistons, SFI balancer
ZZP oversized radiator
Meziere billet flex plate
Meziere Electric Water Pump, polished
Intense stage 4 heads with 1.7 yella terra rockers
MLS head gaskets .052
Intense stage 3 blower cam with timing chain
Comp Cams OE-R lifters
8 rib conversion with all pulleys from smooth flow
Stage 3 Phenolic IC
ZZP fuel logs
80 lb injectors
E85
Walbro pump
Alt rewire
caspers fuel pump rewire
boost a pump
gen V with 2.6 pulley
Northstar TB
Full SLP exhaust plus headers
Intense Trans with 3.29 gears and 3000 converter
Baer brakes
Prepping for paint
And painted zzp shortblock
1.7 Yella Terra Rockers
JP Billet Timing set (single....obviously)
Painted Alt
Painted Baer brakes
crappy night pic
Drew owner of power plus performance on the right and Noah on the left
Freshly painted gtx hood
