#661
Re: selliott turbo gp
GXP Level Member
07-15-2018
What bore is your engine?
#662
I break stuff
07-16-2018
GTPpower
2 over (.020)
#663
GXP Level Member
07-17-2018
I did some searching. It looks like stock head gaskets work with a .020" overbore. I would just buy some new Mahle's on rock auto.
#664
I break stuff
07-17-2018
I have the felpro ones should I switch? I haven't opened them yet?
#665
GXP Level Member
07-17-2018
Which Felpro's do you have?
#666
I break stuff
07-17-2018
These
Sent from my Pixel XL using Tapatalk
#667
GXP Level Member
07-18-2018
Those are the good ones. Keep them.
#668
I break stuff
#669
07-19-2018
mine we also not 100% round, neither were the stock gaskets when i pulled my heads off the blown up engine.
the fat edge is the seal i suppose, once its crushed in place.
i also hit them with copper gasket spray on both sides.
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#670
Turbo is the way to go.
07-19-2018
The chamber opening on the cylinder head is not round, that's why.
You can see on the head where the little step down parts on each side, those match up with the gaskets.
I break stuff
07-19-2018
Fivefingerdeathpunch
Sweet thank you
#672
07-19-2018
I didn't see the first picture where the gasket was there but the cylinder head chamber is not completely round at the top from what I remember and from various pictures. The gasket isn't a perfect match but it follows the lines pretty close.
07-19-2018
Pic for reference.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#674
GXP Level Member
07-20-2018
~James~ Psychotic Gearhead
#675
07-20-2018
In to see shea grind his block!!!!!!!!!!!!!!
Post Thanks / Like - 0 Thanks, 0 Likes, 1 Dislikes
#676
I break stuff
07-20-2018
ItHurtz
I'm all over it!
#677
GXP Level Member
07-21-2018
Stock blower junk > turbo
#678
07-21-2018
^^^ things that never run! I like this game
#679
I break stuff
07-21-2018
Turbocharged400sbc
Well isn't that purdy
#680
GXP Level Member
07-22-2018
ItHurtz
Turtleman already took the first test drive
FGT very unfinished intercooler setup - YouTube
