I'm gonna see how it does without the fan and go from there
His current is a baby tube and fin
Your gxp also has no power lol
Haha. Burn
Cooler installed after an hour of stop and go with a mix of highway it had a max temp of 194 which is better but I'd like it to be lower. It is 115 degrees outside tho.
Pics of its location?
I don't right this second, but its up at the top of the radiator bc the air from the 2 upper vents flow directly over the top of the ic and hit the cooler without to much blockage
make a shroud so all the air is forced through the ic/rad/cooler
paint the card board?
aluminum flashing or plastic sheets work.
Wait for ambient temps to come down I bet the trans temp will follow suit.
With 115ยบ ambient I wouldn't complain at all about 190's. The fluid is the most happy between 170-190 anyway, pretty much the butter zone for fluid life and heat for proper flow/lubrication.
no replacement for displacement doesn't count when the lesser is more
