I had leaking intake gaskets when I bought the car as he said it was overheating and that he had replaced the water pump but that it didn't fix it. I replaced the radiator, installed a new thermostat (since it didn't have one) new radiator hoses, GM intake gaskets and a new SC gasket along with new valve cover gaskets. All of the surfaces were cleaned properly and torqued to spec. But... while trying to purge the air out of the system, I keep getting a surge of air in the coolant. If I rev up the engine I can see it forcing the coolant into the overflow bottle. Not to mention I still don't have any heat. Also I get fluid in the pocket in the LIM closest to the thermostat. I inspected the LIM when it was off but I'm starting to think that it has a crack and the forced induction it forcing air into the coolant. That or the gaskets aren't sealing it off. Any one have any ideas? This thing is killing me! I just want to get it running properly so I can sell it.
