WD40 or brake clean work wonders...vacuum system hates it...so it'll run your idle up if it is in fact a vac leak in one of the rubber/plastic lines that are known for dry rotting.
seafoam is also another good check if you run it through your vac lines. its best for detecting exhaust leaks though.
Sweet. Thanks for all the responses. Hopefully ican get to it this week. B eing military I haent had much time lately
ok well i took the belt of my the sc and was moving the pulley. there is a lot of play in it is that good? i have another sc and there is not that much play in ti though
