Thread: Throwing codes
Results 1 to 6 of 6
  1. #1 Throwing codes
    SE Level Member batman1988's Avatar
    Junction City, Kansas
    I went to autozone a while ago and ran the codes on the car. I got "bank 1 to lean" and "cylinder 3 misfire". I checked my o2 extension wires and my buddie wired up the 2 brown wires wrong. I fixed those and the cyl 3 misfire went away. I am still getting bank 1 to lean. I have had all the injectors flow matched and even changed the plugs. It is still throwing the code. Before my gas milage was really bad, i went 200 mi before i had to fill up. Now i am at 168mi and still have 5/8 a tank left. So today i went to autozone and grabbed there scanner and this is what i got. I dont know if this will help out any or not. All i can say is HOLY TIMING ADVANCE BATMAN!
    TPS(%) 0.0-0.4
    RPM 780-822
    CALC LOAD(%) 2.0
    MAF(LB/M) 0.00
    MAP("HG) 10.0
    COOLANT 180 DEG
    IAT 133 DEG
    IGN ADV (DEG) 20.5-22.0
    ST FTRM1 3.9%
    LT FTRM1 -10.9%
    FUEL SYST 1 CLSD
    FUEL SYST 2 N/A
    o2S11(V) 0.030-0.900
    ST FTRM11 -1.6
    o2 S12(V) 0.450
    That is what the scanner showed. So is my 3800 performance PCM causing bank 1 to run to lean?
    04 ESCALADE ESV: Wife's DD
    98 Buick Regal GS: Stock
  2. #2 Re: Throwing codes
    wouldnt the lean code be a cat code????
    and yes timing adv is always high like that when at idle and crusing.
    22ish at idle
    around 30 crusing
    Timing at WOT will varie as to what the tune is set at.
  3. #3 Re: Throwing codes
    I have a cat-delete and when i ordered the tune from 3800performance they deleted the code off of the car from the second o2 sensor. It ran fine before before for almost a year and a half.
  4. #4 Re: Throwing codes
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    vac leak. At idle do the LFT's go to 16.4?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: Throwing codes
    I have no idea honestly, that is all the scanner would give me for information.
  6. #6 Re: Throwing codes
    So i found out that i have a major exhaust leak from my rear header to my EGR. Could this be throwing the code?
  1. Throwing all my GTP parts into the trash
    By BobC in forum 1991-1994 5 speed Manual (GETRAG 284,282)
    Last Post: 08-13-2011, 06:42 AM
  2. '02 Grand Prix throwing DTC code after visit to garage
    By devwar in forum General Tech Discussion
    Last Post: 08-31-2010, 03:58 PM
  3. throwing a code ive never seen before, helppp!!
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2010, 08:06 PM
  4. Mark Forums Read throwing an error
    By Scimmia in forum Forum Bugs/Suggestions
    Last Post: 05-28-2010, 01:10 PM
