Thread: Vaccum issue?
Results 1 to 5 of 5
  1. #1 Vaccum issue?
    SE Level Member Sl33p3rGt's Avatar
    Dec 2010
    Modesto
    Ok i swapped a 99gtp motor and pcm into my 98gt
    everything is tits i believe but i think im having some vaccum issues,I get lopey idle and a lean bank1 code.
    Now idk if this is right or not but it has seemed to work...lol
    i plugged the hose that controls my interior ac controls,to the middle
    of the vaccum tree is that correct? If im not mistaken i thought somthing was supposed to see atmosphere pressure or is that just for swaps with the gt pcm?
    Also everythime i got to get gas and remove the cap pump my life away,then go to start it,it runs horribly for a few seconds very bad up and down idle then clears out?
    seems to have weak power
  2. #2 Re: Vaccum issue?
    SE Level Member FETGYK06GP's Avatar
    north America
    Quote Originally Posted by Sl33p3rGt View Post
    Classic symptoms of a vac leak.
    Don't know about the connection but just cap the tree as a test.
    Also everythime i got to get gas and remove the cap pump my life away,then go to start it,it runs horribly for a few seconds very bad up and down idle then clears out? seems to have weak power
    Be sure not to over fill. If you can afford to fill up these days. lol
    Vac and fuel pressure are were I would start.
  3. #3 Re: Vaccum issue?
    Dec 2010
    Modesto
    ah nice...blocked it off seems to be idleing nice now thanx.
    I bet having that hooked up to the ac control vac,was just enough to keep it running decent with a vac leak...lol
    appreciate the help
  4. #4 Re: Vaccum issue?
    north America
    Or the vac leak is on the AC side.
  5. #5 Re: Vaccum issue?
    Dec 2010
    Modesto
    Yeah it seems to be running way better now,i just plugged it and the idle issues went away,along with loss of power.Thanks again
  1. Where to buy A/c system vaccum.
    By Wakeboy1337 in forum General Tech Discussion
    Last Post: 04-14-2011, 02:47 AM
  2. vaccum line diagram 97 gtp
    By prettyboimike12 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2011, 08:59 PM
  3. Replacing Vaccum Modulator
    By mainecrab in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2011, 02:49 AM
  4. vaccum hose?
    By kingd44 in forum General Tech Discussion
    Last Post: 10-13-2008, 05:35 PM
  5. Huge vaccum leak at the PCV tee...
    By alacran in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2008, 04:27 PM
