Thread: oil pressure light
Results 1 to 8 of 8
  1. #1 oil pressure light
    SE Level Member 99blkgtp's Avatar
    Jun 2010
    Avon,IN
    so my car was finally put back together today and started for the first time with the cam and heads. but as soon as we started it the oil pressure light came on so we shut it off. checked to make sure the sensor was plugged in and cleaned it off. also checked the oil filter. where should i start? also the vaccum was only reading 10, shouldnt it be higher even with the cam untuned?
    99 Gtp - L32, xp, ported heads 130#s, 2.5" IC, n*, ported gen3, SD headers, 3" exhaust, FWI, 160* stat, 103s, 2.8, E85, PRJ tune......Sold
    04 Comp G - Slammed on Bilstein Coilovers, few little mods here and there
  2. #2 Re: oil pressure light
    Jersey
    did u put back together the pressure cylinder and spring thingy back together properly?
    16' wrx sti- stock
  3. #3 Re: oil pressure light
    Houston
    Good time to get an oil pressure gauge, so you know for sure what your pressure is at.
  4. #4 Re: oil pressure light
    I'd suggest the gauge as well. A manual gauge is a great thing to have, even though you won't use it often. The times you do..it's priceless.
    I know because I've been in your situation.
  5. #5 Re: oil pressure light
    did you reassemble the oil pump gear how it was supposed to be? my problem when i did my swap is that i had no oil pump gear in the car.
  6. #6 Re: oil pressure light
    Jun 2010
    Avon,IN
    my friend whos been helping me did all the bottom end work since he had already put and xp cam in his car, but he didnt run a double roller so it was new to him. he said he didnt change anything with the cover off, just pulled it off and put the machined cover on. paul at prj is saying your supposed to pack it with lube inside there before you put it back on, which he didnt. so thats what were thinking is the issue.
  7. #7 Re: oil pressure light
    If you didn't pack it with vasoline or whatever, then unhook the coil pack module and crank it a few times. It should self prime.
    If you've had it running and the light flashed..a gauge is the only way to know what's really going on.
  8. #8 Re: oil pressure light
    Jun 2010
    Avon,IN
    ya we ended up pumping oil into it and priming it. its got pressure now. heres a video of it open header. who needs exhaust lol
    YouTube - Grand Prix GTP XP cam with open header first start
  1. ABS and check tire pressure light on
    By GTP2188 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2010, 02:12 PM
  2. ABS and check tire pressure light on
    By GTP2188 in forum Brakes/Suspension/Chassis
    Last Post: 11-15-2010, 07:00 PM
  3. Oil pressure light came on help....
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2009, 06:59 PM
  4. tire pressure light
    By ibanez0110 in forum Brakes/Suspension/Chassis
    Last Post: 12-06-2008, 03:01 AM
  5. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
