Thread: Engine Won't Start After Running for a bit
Results 1 to 13 of 13
  1. #1 Engine Won't Start After Running for a bit
    Texas
    Okay so I thought I was done with this problem but I guess the cold weather only disguised it. When I run my car for a little bit or for a long time I will turn it off and then when I want to start it up again it won't start. I always have to end up waiting about 30 to 45 minutes depending on how much it was run until it cools down and then it will start again.
    I don't really know what this is and what is causing this.
    So far, I know it can't be any of these because I barely changed them;
    - Spark plugs
    - fuel filter
    What I am thinking is that it may be any of these or something else I don't know;
    - fuel pump
    - spark plug wires
    Anyone have any input on this? Anyone with a similar problem or has dealt with a similar problem? When my car is cool it will start up really fast and like a champ.
  2. #2 Re: Engine Won't Start After Running for a bit
    it sounds like more of an electal problem..like a sensor or a bad wire..do you have access to a scan tool
    sorry for my spelling
    SMGPFC Member #10
  3. #3 Re: Engine Won't Start After Running for a bit
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Might be a bad oxygen sensor. Seems like your car stays running when in open loop mode but stops in closed loop mode (operating temps). If you know someone with a scanner I would see what your 02s are doing when the car warms up.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  4. #4 Re: Engine Won't Start After Running for a bit
    ^yup
    thats why i said something like a sensor
    an input to the pcm that helps it switch for open to closed loop
    is you MIL light on?
    SMGPFC Member #10
  5. #5 Re: Engine Won't Start After Running for a bit
    Texas
    Nah, no lights are on except for the low coolant level but it's full and the car does run at normal and steady temp.
    What kind of scan tool would I need? Would an OBD II do the job or would I need a Tech II scanner to diagnose the O2 sensor?
  6. #6 Re: Engine Won't Start After Running for a bit
    anyone will work as long as it has pids
    SMGPFC Member #10
  7. #7 Re: Engine Won't Start After Running for a bit
    Texas
    Aight cool, any other possible issues that this could be?
    Hmm, now I remember about a year or more ago I was stuck in a gas station with this issue. A mechanic came and he took off one of the spark plug wires, it began to spark (don't remember if it wasn't sparking before he took it off or not) and then the car worked.
  8. #8 Re: Engine Won't Start After Running for a bit
    did you check the plug wires?
    salt water and a spray bottle and see if it arc's to the block
    and if you have a dmm check the ohms across the wires and see if one is messed up
    SMGPFC Member #10
  9. #9 Re: Engine Won't Start After Running for a bit
    Texas
    That sounds dangerous, how exactly is that done?
  10. #10 Re: Engine Won't Start After Running for a bit
    just spary the wires with the salt water while the car is running and if theres like a pin hole in one of the wires the salt will act like an conductor and arc to the closest ground and thats normal the block, just dont hold the wires and u'll be fine, oh and if it happens it will cause a misfire and the motor will bog down and then you'll know that you have a bad plug wire, or if you dont want to do that then you can get a dmm and do a resistance test on the wires and see if there still in spec, thats another way to check the wires with the car off
    SMGPFC Member #10
  11. #11 Re: Engine Won't Start After Running for a bit
    SE Level Member gtx3800's Avatar
    Gillespie, IL
    Heat soaked coils or even your ECM could be the culprit.. Start unpluggin sensors to eliminate them as the problem. It will trip a light but if it doesnt get a reading from a sensor it will revert to a default setting in the ECM. If you unplug it and it stops acting up, replace it.
    THERE IS NO REPLACEMENT FOR DISPLACEMENT!
  12. #12 Re: Engine Won't Start After Running for a bit
    Texas
    Hmm, I've thought about it being the coils as well...could it be just one or is it always all of them?
  13. #13 Re: Engine Won't Start After Running for a bit
    well theres 3 of them since its a waste spark system, one coil pack for each set of
    companion cylinders
    SMGPFC Member #10
  1. 00 Grand Prix Won't stay running/start
    By bankai in forum General Tech Discussion
    Last Post: 10-10-2011, 11:37 PM
  2. Car running rough and won't start sometimes
    By metallica350 in forum General Tech Discussion
    Last Post: 12-02-2010, 09:43 AM
  3. 2000 gtp wont stay running after start??
    By handymontana in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2010, 06:42 AM
  4. Engine running hot
    By 04GTPCOMPG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2009, 08:26 PM
  5. Won't start after running out of gas
    By DesQ27 in forum General Tech Discussion
    Last Post: 02-13-2009, 07:59 PM
