Who on here is running a top swap with a smaller pulley with no trouble.
getting car tuned in a few weeks and would like to try a 3.4 or 3.5. Is it possible without an IC? Vs cam . Headers. Ported blower. 180 therm
How much boost is that? 10 lbs?
Also, how much timing is he running?
For a VS i'd try a 3.4 or 3.5.
to run a 3.4 you need 42.5 injectors or bigger, and a rewire.
I was reallyjyst thinking on using a 3.5. I wouldreally like to hit the 300 HP mark
you didnt run out of injector but your were running over 100percent IDC. Which isnt a great idea.
IPW is not IDC.
85% IDC or higher is unideal.
never said you cant.
I just know 85% IDC is bad.
Couldnt tell you what that would be in IPW.
IDC's are hard to go off of too. There have been guys to show 120% IDC on there logs on a DSM or a 3000GT/Stealth. Obviously you can't go over 100% so most people try to keep it around 80-85%
unless i see knock and the car starting to run lean up top, then i would never swap injectors. this is why EVERYONE needs to run a wideband on any car they want to make power with.
factory wideband for more win?
