Thread: cutting out under a load
Results 1 to 11 of 11
  1. #1 cutting out under a load
    Apr 2011
    Peoria, Illinois
    Hello everyone! I am a new member, but have been reading here for a while.
    I bought a 2004 GTP a month ago with 99k miles. The day after I bought it the check engine light came on and gave a code for a "knock sensor bank 2 low". I run 93 octane fuel, I replaced plugs and wires, and eventually replaced the knock sensor itself. Still getting the same code.
    This is new and not sure if it is related. The car idles perfect and even revs smoothly when parked. When I put it in gear it give it gas, it cuts out or chugs. The plugs and wires are 2 weeks old. The fuel pressure was reading 52 psi, so we replaced the fuel pump assembly and the fuel filter. Nothing changed. If I push the gas to the floor it will accelerate, but it chugs and you can hear predetination. The check engine light will flash if I accelerate moderately.
    I have a good mechanic working on it, but there is probably more knowledge here than any 1 mechanic can hope to have. I would appreciate any assistance. Thanks!
  2. #2 Re: cutting out under a load
    OH boy.. where to start.
    Smack your hand for not fixing the knock issue originally (that's if you didn't...if you did..your good)
    Kinda sounds like a maf sensor, but it could also be sounding like a plugged cat. Did you change the plugs at the same time? I'm going to jump around further and ask.. are any plug wires touching the O2 wiring? That does this kind of thing as well.
  3. #3 Re: cutting out under a load
    Apr 2011
    Peoria, Illinois
    Fuel pressure was a bit low and we believed that it may have been causing the knock by being to lean. I just checked the O2 sensor wires and all is clear of that. I brought up the cat to my mechanic and he said the cat doesn't usually go bad all of a sudden. I will ask that he checks it anyway at this point. Will the car still idle fine with a bad MAF? I believe that can be checked with a meter.
    Another thing to mention is I am still getting excellent fuel economy. I was out of town when it started acting up and still got 29 mpg coming home 6 days ago.
  4. #4 Re: cutting out under a load
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Maybe check the knock sensor wiring? I'm not sure how bad it cuts, but that could be the PCM taking off timing because of the knock or false knock.
    Flashing SES light means miss firing by the way.
  5. #5 Re: cutting out under a load
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Check coils as well. Also, what DTC is coming up?
  6. #6 Re: cutting out under a load
    Apr 2011
    Peoria, Illinois
    It is fixed. The plugs I put in 3 weeks ago went bad. They were replaced under warranty. I put in autolites first, they are garbage. I replaced them with AC delcos.
  7. #7 Re: cutting out under a load
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    FWIW I have been running autolites for years now with no problems heavily modded. And a cat can go bad if youre getting misfires because those can damage it so your mechanic is technically wrong there.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  8. #8 Re: cutting out under a load
    Apr 2011
    Madrid, IA
    I have the same problem. Replaced the MAF with no results. The new plugs still doing the trick?
  9. #9 Re: cutting out under a load
    GT Level Member starscream5000's Avatar
    Kentucky
    Make sure the plugs are gapped correctly and that you have quality plug wires on there with dielectric grease.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  10. #10 Re: cutting out under a load
    SE Level Member gtx3800's Avatar
    Gillespie, IL
    Quote Originally Posted by Bedwards View Post
    ^^^ Coils X2
    THERE IS NO REPLACEMENT FOR DISPLACEMENT!
  11. #11 Re: cutting out under a load
    Apr 2011
    Peoria, Illinois
    The plugs are still working great. The car is not cutting out at all.
  1. Cutting the bumper on your struts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 06-16-2011, 01:11 PM
  2. radio cutting out
    By gtcoup in forum Off Topic Discussion
    Last Post: 12-26-2010, 01:25 AM
  3. Cutting fuel lines
    By Sabrewings in forum General Tech Discussion
    Last Post: 06-26-2009, 12:14 AM
  4. ses codes and car cutting out
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2008, 12:33 PM
  5. Car Cutting out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-31-2008, 04:48 PM
