Thread: Running lean
Results 1 to 7 of 7
  1. #1 Running lean
    SE Level Member camarofan1974's Avatar
    Apr 2011
    agawam
    i have a 98 gtp mods:3.4, pcm, cai, downpipe,cat resonator and u-bend delete, 3in exhaust into chambered mufflers, ported exhaust manifolds,ported tb lim and s/c, msd coil packs wires, 104 plugs , t-stat, a/c delete, and poly motor mounts. ive checked for vaccume leaks- none ,maf-fine...could i be just flowin too much air and would injectors help? if so what size?
  2. #2 Re: Running lean in one bank?
    No...you don't need injectors, you need a tune. When you ported your throttle body it skewed your MAF readings bad.
  3. #3 Re: Running lean in one bank?
    P0171 ... please search on that code with my name.
  4. #4 Re: Running lean in one bank?
    Jan 1970
    Maquoketa, Iowa
    Let me google that for you
  5. #5 Re: Running lean
    Ok..pm me how you did that...that was cool.
  6. #6 Re: Running lean
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    vac leak, keep looking. No way in hell a ported TBs gonna skew that much.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  7. #7 Re: Running lean in one bank?
    Apr 2011
    agawam
    i know someone with a tuner, but im afraid of screwin up the tune from 3800perf...computers arrent my strong suit
  1. running lean?
    By Brennan7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 10:07 AM
  2. Running lean in one bank?
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2010, 01:22 PM
  3. Running Lean
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2010, 02:06 AM
  4. Engine running lean
    By crd783 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2009, 01:26 AM
  5. STILL running lean..why!?
    By BwolfGT in forum General Tech Discussion
    Last Post: 10-22-2009, 12:26 AM
