Thread: L67 vs L32 Heads, casting #, how to tell the difference?
Results 1 to 3 of 3
  1. #1 L67 vs L32 Heads, casting #, how to tell the difference?
    GT Level Member RegalGS98s's Avatar
    NJ
    I've heard from different vendors and seen on Wikipedia the L32 Heads have a better flow design and 1.83" instead of 1.8" intake valves on the L67 Heads. I also saw on fullthrottlev6 the L32 exhaust valves are sodium filled. For these reasons, I was trying to purchase a set of used L32 heads, but after a month a recent deal fell through which I'm still awaiting a refund.
    I decided I'm going to buy a set of remanufactured heads. Most the parts stores have the same part # if I look up heads for a 1998 or a 2007. Some stores like Advance Auto have the same casting # listed for both years as well of #4781. Some like NAPA have different head castings available, but I don't know what years the head casting #'s relate.
    Is there different head casting #'s for L67 and L32 Heads? If so where can a list be found? When Heads are remanufacturered, are they using the heads and valves found on the newer designed L32 or are they just taking both L67 and L32 heads and putting the same part # on them so you don't know what heads you are getting until you measure the valve size? To me that would make a running problem if one of the heads you receive has the 1.83" intake valves and the other has 1.8" intake valves.
    Thanks for any help.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  2. #2 Re: L67 vs L32 Heads, casting #, how to tell the difference?
    NJ
    I've spoken with a couple re-manufacture companies. They think the heads are exactly the same from 97-07. They checked AllData and couldn't find any differences. When I told them the below information about the heads in my hands, they said the one's with the 1.83"; intake valves must be aftermarket. I checked the 2 sets of heads I have and the L67 do measure 1.8"; for the intake and the L32 measure 1.83";. Both heads have a cast# of 4781 and the exhaust valves both measure 1.52";. I spoke with Eric of Morad and he says they're the same head, just the L32 have the larger intake valves with a different angle seat cut to seal better. Does anyone know where some of this information can be referenced? Did GM keep the same cast# but change the flow design?
  3. #3 Re: L67 vs L32 Heads, casting #, how to tell the difference?
    the only difference is the intake valve being slightly oversized on the L32 heads. the casting themselves are identical.
  1. difference between 04-05 gtp and 06-07 gt?
    By miller in forum Off Topic Discussion
    Last Post: 04-12-2014, 06:36 PM
  2. Can anyone tell me the difference?
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 01-27-2011, 02:36 AM
  3. any difference?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 08-03-2010, 07:10 PM
  4. difference between gen 2 and gen 3 heads
    By selliott in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2009, 12:20 PM
  5. Is there a difference between 05 and 06 GXP
    By baw1099 in forum Off Topic Discussion
    Last Post: 06-29-2008, 10:17 PM
