Thread: Harness for coolant temperature sensor
Results 1 to 10 of 10
  1. #1 Harness for coolant temperature sensor
    SE Level Member Duffman's Avatar
    Mi
    hello everyone, so i swapped out my old engine for a fresher one from morad. the day after i took my engine out someone stole it from my driveway, and i never got the whip that connects to the coolant temp sensor to the main harness off the engine. i assume i can just call morad and get one shipped, i was wondering what else that little harness hooked up to though. i know it starts at the 3 prong connector near the front valve cover, and goes to the ect, but where does it run from there? i couldn't see any other open connectors or sensors that were near by the ect
  2. #2 Re: Harness for coolant temperature sensor
    Omaha, NE
    I'm not certain that morad would give you just that portion, you may need to get a whole new harness, which may be the best way to go. Slicing wiring harness wires can sometimes create problems.
  3. #3 Re: Harness for coolant temperature sensor
    Mi
    i didn't think i needed to do any splicing. i read in another thread that the section i'm missing is detachable like the crank/cam sensor section. but if it involves spicing i will definatly go with a whole new harness
  4. #4 Re: Harness for coolant temperature sensor
    Omaha, NE
  5. #5 Re: Harness for coolant temperature sensor
    Nope...it's in a triangular pattern...not flat like that one.
  6. #6 Re: Harness for coolant temperature sensor
    Donating Users
    South Deerfield, MA
    It doesn't hook up to anything else. It only connects to the ect sensor.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  7. #7 Re: Harness for coolant temperature sensor
    Mi
    and from the ect sensor it connects to the big empty connector on my front valve cover with the green, yellow, and black wires? don't mean to be redundant, just want to know what i'm asking for when i call around tomorrow
  8. #8 Re: Harness for coolant temperature sensor
    Omaha, NE
    If you can, post up a picture, that might help narrow it down. Somebody may be able to give you a proper name as well.
  9. #9 Re: Harness for coolant temperature sensor
    Banned
    Sioux Falls, SD
    Are u asking for the harness? if so i have one
  10. #10 Re: Harness for coolant temperature sensor
    Quincy, Mass
    you can get the connector pigtails from rockauto.com
    No more GP 04 Impala SS Indy:
  1. Replacing coolant temperature sensor
    By vertebrate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2013, 01:43 AM
  2. Installing the Coolant Temperature Sensor Problems
    By ZackN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2011, 04:39 PM
  3. Wheel Speed Sensor Wireing harness
    By packerfanjc in forum Tires & Wheels
    Last Post: 02-16-2011, 10:09 AM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  5. o-ring for temperature sensor?
    By nlinesk8s in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2010, 04:06 PM
