Thread: need help asap no injector pulse 5th cyl
Results 1 to 4 of 4
  1. #1 need help asap no injector pulse 5th cyl
    buffalo
    I've always wanted a gtp I found one drove fine then it started to have a mis fire in number five changed plugs wires no luck hooked up a noid light and nothing on 5 hooked up a pcm from a s/c Buick riv and the noid lit up but the car wouldn't run bought a new pcm and had it flashed and its still doing the same thing car runs but there's no pulse to number 5. Any ideas please help I got close to a grand in to this thing I've owned it 3 weeks and got to drive it once
  2. #2 Re: need help asap no injector pulse 5th cyl
    Omaha, NE
    Could be the wire harness.
  3. #3 Re: need help asap no injector pulse 5th cyl
    Quincy, Mass
    ^^ agreed its probably the wiring, is the injector connector connection clean?
    No more GP 04 Impala SS Indy:
  4. #4 Re: need help asap no injector pulse 5th cyl
    buffalo
    Well like said I don't think its the harness cause we pulled the sheld off the wires and its all good and with the pcm off the Buick the noid lit up and worked the car just wouldn't start but all the injectors worked
  1. P0753, P0758, P1860, 1-2 and 2-3 shift solenoid and TCC pulse width modulator errors
    By STOCKTA in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2013, 08:36 AM
  2. How-to add LED's & have them pulse from amplifier
    By mousemonster1232 in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2011, 06:46 PM
  3. Wiper Pulse board or Multi function control
    By JGN in forum General Tech Discussion
    Last Post: 06-09-2010, 02:55 PM
  4. Pulstar pulse plugs?
    By a98gtp4u in forum General Tech Discussion
    Last Post: 09-20-2009, 08:47 PM
  5. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
