Thread: L32 rod bolts torque settings?
Results 1 to 15 of 15
  1. #1 L32 rod bolts torque settings?
    Sydney
    Anyone know?
    Cheers.
  2. #2 Re: L32 rod bolts torque settings?
    Kansas
    Give me a sec I'll look it up.
    SOLD 1999 GT Silvermist TS
  3. #3 Re: L32 rod bolts torque settings?
    Kansas
  4. #4 Re: L32 rod bolts torque settings?
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Fastener Tightening Specifications
    Application
    Metric
    English
    Accelerator Control Cable Bracket Bolt
    16 N-m
    12 lb ft
    Air Injection Check Valve Pipe to Exhaust Manifold
    10 N-m
    89 lb in
    Air Injection Check Valve to Bracket Bolt
    25 N-m
    18 lb ft
    Balance Shaft Driven Gear Bolt
    22 + 70° N-m
    16 + 70° lb ft
    Balance Shaft Retainer Bolt
    30 N-m
    22 lb ft
    Camshaft Position Sensor Bolt
    10 N-m
    89 lb in
    Camshaft Sprocket Bolt
    100 + 90° N-m
    70 + 90° lb ft
    Camshaft Thrust Plate Bolt
    15 N-m
    11 lb ft
    Canister Purge Solenoid Valve Bracket Bolt
    50 N-m
    37 lb ft
    Canister Purge Vacuum Switch Bolt
    50 N-m
    37 lb ft
    Connecting Rod Cap Bolt
    27 + 50° N-m
    20 + 50° lb ft
    Crankshaft Balancer Bolt
    150 + 76° N-m
    111 + 76° lb ft
    Crankshaft Main Bearing Cap Bolt
    40 + 110° N-m
    30 + 110° lb ft
    Crankshaft Main Bearing Cap Bolt (Side)
    15 + 45° N-m
    11 + 45° lb ft
    Crankshaft Position Sensor Stud
    30 N-m
    22 lb ft
    Crankshaft Rear Oil Seal Housing Bolt
    15 + 50° N-m
    11 + 50° lb ft
    Cylinder Head Bolt
    50 + 120° N-m
    37 + 120° lb ft
    Drive Belt Tensioner Bracket Bolt/Nut
    50 N-m
    37 lb ft
    Drive Belt Tensioner Bracket Stud
    6 N-m
    53 lb in
    EGR Valve Adapter Bolt/Stud
    50 N-m
    37 lb ft
    EGR Valve Inlet Pipe Bolt
    29 N-m
    21 lb ft
    EGR Valve Nut
    30 N-m
    22 lb ft
    EGR Valve Outlet Pipe Bolt/Nut
    29 N-m
    21 lb ft
    Engine Block Coolant Drain Plug
    30 N-m
    22 lb ft
    Engine Block Oil Gallery Plug
    30 N-m
    22 lb ft
    Engine Coolant Temp Sensor
    23 N-m
    16 lb ft
    Engine Flywheel Bolt
    15 + 50° N-m
    11 + 50° lb ft
    Engine Front Cover Bolt Stud
    20 + 40° N-m
    15 + 40° lb ft
    Engine Lift Bracket Bolt/Nut./Stud
    30 N-m
    22 lb ft
    Engine Mount Nut Lower
    78 N-m
    58 lb ft
    Engine Mount Nut Upper
    78 N-m
    58 lb ft
    Engine Oil Pressure Indicator Switch
    16 N-m
    12 lb ft
    Engine Wiring Harness Heat Shield Nut/Bolt
    10 N-m
    89 lb in
    Exhaust Crossover Heat Shield Nut
    20 N-m
    15 lb ft
    Exhaust Crossover Pipe Bolt/Stud
    18 N-m
    13 lb ft
    Exhaust Manifold Bolt/Nut
    30 N-m
    22 lb ft
    Exhaust Manifold Stud (Inner)
    30 N-m
    22 lb ft
    Exhaust Manifold Stud (Outer)
    10 N-m
    89 lb in
    Fuel Injector Rail Nut
    10 N-m
    89 lb in
    Fuel Injector Rail Stud
    25 N-m
    18 lb in
    Fuel Injector Sight Shield Bracket Nut
    30 N-m
    22 lb ft
    Generator Brace Bracket Bolt
    50 N-m
    37 lb ft
    Heated Oxygen Sensor
    42 N-m
    31 lb ft
    ICM Nut
    50 N-m
    37 lb ft
    ICM Stud
    6 N-m
    53 lb in
    ICM Wiring Harness Bolt
    2 N-m
    18 lb in
    Idler Pulley Bolt
    50 N-m
    37 lb ft
    Idler Pulley Bracket Bolt
    30 N-m
    22 lb ft
    Lower Intake Manifold Bolt
    15 N-m
    11 lb ft
    Oil Cooler Adapter Connector
    50 N-m
    37 lb ft
    Oil Filter
    30 N-m
    22 lb ft
    Oil Filter Adapter Bolt
    15 + 50° N-m
    11 + 50° lb ft
    Oil Level Indicator Switch
    20 N-m
    15 lb ft
    Oil Level Indicator Tube Nut
    19 N-m
    14 lb ft
    Oil Pan Bolt
    14 N-m
    125 lb in
    Oil Pan Drain Plug
    30 N-m
    22 lb ft
    Oil Pump Cover Screw
    11 N-m
    98 lb in
    Oil Pump Screen Bolt
    15 N-m
    11 lb ft
    Power Brake Booster Heat Shield Nut
    20 N-m
    15 lb ft
    Spark Plug
    27 N-m
    20 lb ft
    Starter Motor Heat Shield Bolt
    30 N-m
    22 lb ft
    Throttle Body Nut
    10 N-m
    89 lb in
    Throttle Body Support Bolt
    10 N-m
    89 lb in
    Throttle Body Support Stud
    6 N-m
    53 lb in
    Timing Chain Dampener Bolt
    22 N-m
    16 lb ft
    Upper Intake Manifold Bolt/Stud
    10 N-m
    89 lb in
    Vacuum Solenoid Valve bolt (with NC1 California Emissions)
    10 N-m
    89 lb in
    Valve Lifter Guide Retainer Bolt
    30 N-m
    22 lb ft
    Valve Rocker Arm Bolt
    15 + 90° N-m
    11 + 90° lb ft
    Valve Rocker Arm Cover Bolt
    10 N-m
    89 lb in
    Water Outlet Bolt
    27 N-m
    20 lb ft
    Water Pump Bolt
    15 + 80° N-m
    11 + 80° lb ft
    Water Pump Pulley Bolt
    13 N-m
    116 lb in
    Wiring Harness Shield Bolt/Nut
    10 N-m
    89 lb in
    Lambokit to be built!!!!!
  5. #5 Re: L32 rod bolts torque settings?
    Sydney
    Thanks guys but arent those specs for L67?
    Ive done my bolts to 22nm + 70deg. Somebody told me thats what was in his workshop manual for L32 and im just making sure.
  6. #6 Re: L32 rod bolts torque settings?
    gpona.com has the GM service manual.
    Install the connecting rod bearing cap bolts.
    Tighten
    Tighten the connecting rod bearing cap bolts to 27 N·m (20 lb ft) + 50 degrees using J 45059 .
    You need to plastiguage it anyways.
    Have you done that yet?
  7. #7 Re: L32 rod bolts torque settings?
    Kansas
    Quote Originally Posted by That Canadian Guy View Post
    Don't need to, but highly recommended!
  8. #8 Re: L32 rod bolts torque settings?
    Sydney
    No, i torqued the rods up outside of the motor and used an inside micrometer.
    I probably should mention im from australia before i go any further lol.
    Here is AUS the L32 rods came out in our L67 from late 2003 to late 2004.
    Here is our service manual.
    The ''Early'' type rods are the L67 and the ''Late'' rods are the L32's.
    Mind you i bought the L32 rods from the U.S.
    I think the only difference with torqueing the bolts is the main caps squashing in more or less depeding on what setting used. Im just worried the bolts might snap under load from being too tight.
    What do you guys think?
  9. #9 Re: L32 rod bolts torque settings?
    Kansas
    Well there ya go.
  10. #10 Re: L32 rod bolts torque settings?
    Sydney
    I'll tell you another thing.
    I replaced the original bolts because i had a few problem with the build, the old bolts got torqued too many times. GR8racingfool was kind enough to give me his un-used bolts as he went to ARP's.
    Problem was that his L32 bolts were slightly different to my L32 bolts (Only really the flanges under the hex is slightly smaller) and were 2.3 grams lighter which will now not only throw my full engine balance out slightly.
    This makes me worry that there are different part numbers for L32 rod bolts and different torque settings...
    But if the bolts can handle the extra torque and are just designed to give the cap more squash then it shouldnt be a problem as ive measured the rods while using the tighter torque setting.
    My original bolts are on the right.
  11. #11 Re: L32 rod bolts torque settings?
    the whole world uses plastiguage it takes some time to put together and take apart and put back together, but well worth the time, some times the new bearing is fvcked up and no micrometer is going to tell you that.
  12. #12 Re: L32 rod bolts torque settings?
    Kansas
    ^^ very true, your car your build, do as you wish, I'd plasti everything.
    Blown you should go ahead and order some arp bolts
  13. #13 Re: L32 rod bolts torque settings?
    Sydney
    So you reckon the extra torque setting is to close the bore slightly more?
  14. #14 Re: L32 rod bolts torque settings?
    Wichita, KS
    Replied to your PM.
    27 + 50° N-m
    20 + 50° lb ft
    is what I follow on stock bolts, but like you said I went with ARPs and I followed their specks.
    I always use plastiguage, takes but a few minutes to save a wold of headaches.
    When I built my engine, I removed the L23 rods bolts, from my brand new rods and installed my ARPs and then took them to the machine shop so they could line hone them straight and true again because the different bolts will change the shape of the rod some because of the different torque.
    Stock rods, with the stock bolts, its a good idea to have this dome as well, install the bolts, torque them, and degree them, and have them honed. Though the bolts are TTY and "one time use" You should be fine running them in the engine after this is done. You haven't "used them" for say, but you have to torque them, and stress the cap/bolts to get a true and perfect circle as if it were installed on the crank. From the factory brand new, this is already done to the rods, I would assume...but it never hurts to for sure follow through.
    ~F~
  15. #15 Re: L32 rod bolts torque settings?
    Kansas
    Thanks for stepping in farns.
  1. What bolts are torque to yeild
    By slednut in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2009, 09:53 PM
  2. A/C Settings 1-4
    By JFeezy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2009, 02:15 PM
  3. amp settings
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 09:47 PM
