have codes p 0480 cooling fan 1 circuit malfunction, and p 0481 cooling fan 2 circuit malfunction. my obd2 scanner shows temp is accurate, i do not see nothing wrong with the wiring, also i changed the relays from another vehicle(same), i also tried a different computer. all fuses are good. 2000 gtp.
any ideas? the fans do work, i ran a jumper to power and they both come on. im lost.
