when, and if, you did an CAI or HAI, where and what did you do with your computer?
thanks
thanks
I cleaned the area there under where the air box used to be really well and then I used some double sided sticky tape and put that onto the PCM. In fact I doubled up on it for some vibration cushion, two strips on top of one another.
A strip down both sides length ways and then one across. Put the PCM down on the area that was cleaned, pressed down a little to make sure it mated up real well and it never moved.
This is how mine is set up. I never could understand why my harness was so different from everyone else. I've just not taken the time to peel the tape back, and reset it. But I put my MSD in where the PCM would have been, so it works for me right now.
Heres mine
Mine just sits on a flat piece of rubber with the cai housing pushing down on it so it doesnt move. I plan on going to a fwi next summer as my cai isnt very "c". Then I will zip tie the pcm down on the same piece of rubber.
PCM tray came with my Thrasher airbox. sits right undernieth out of site
