Thread: what is this ticking noise?!?!?
Results 1 to 16 of 16
  1. #1 what is this ticking noise?!?!?
    SE Level Member 2000gpgtp's Avatar
    Jun 2010
    Alaska
    here is a video link, details are in video description. Let me know if you need more details. Kh and i forgot to put on the video, it goes away ehen the car is warmed up, i tried 5w30 oil and it almost muffled it a little but then came back, it sounds to me like its coming from the s/c pulley but not for sure. thanks
    YouTube - 2000 Grand Prix Gtp engine ticking noise help
  2. #2 Re: what is this ticking noise?!?!?
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Sounds like a collapsed lifter to me. Try sea-foaming the engine, or run a quart of ATF in the oil for halfhour before changing the oil. ATF in the oil will NOT do any harm.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  3. #3 Re: what is this ticking noise?!?!?
    Donating Users
    Parma, Ohio
    that tick sounds a little louder then a lifter tick.. but i would try what he said ^^
    2003 Subaru Impreza WRX
    2008 Saturn Aura
    2000 Bright Red GTP coupe. RIP 11/6/11
  4. #4 Re: what is this ticking noise?!?!?
    Jun 2010
    Alaska
    Ok thanks guys! Where do you put the sea foam in with the supercharged engine?
  5. #5 Re: what is this ticking noise?!?!?
    Charles City, IA
    The line going to the brake booster
    SMGPFC Two Nipple General
  6. #6 Re: what is this ticking noise?!?!?
    Charles City, IA
    Oh run it in the oil for like 10min right before you change it.
  7. #7 Re: what is this ticking noise?!?!?
    Ontario, Canada
    Seafoam in the vac line wont help the lifter problem any, but it will clean up the internal top end components. Using it in the engine oil WILL however.
    Jay
  8. #8 Re: what is this ticking noise?!?!?
    what happened to the 100 mile program with running it in the oil?
  9. #9 Re: what is this ticking noise?!?!?
    Charles City, IA
    I know jay I did not read the top posts.
  10. #10 Re: what is this ticking noise?!?!?
    Charles City, IA
    I here you get a new engine from it. lolz
  11. #11 Re: what is this ticking noise?!?!?
    I must sign up for that then.
  12. #12 Re: what is this ticking noise?!?!?
    Apr 2011
    sudbury
    Having the same problem here just happend today . I just doono where to buy sea foam in canada ontario . My canadian tire dosent carry it .. Ill keep investigating the problem after work .. Hoping its not a flywheel issue..
  13. #13 Re: what is this ticking noise?!?!?
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    I would think sea foam is easy to come by everywhere could always try at a boat place cause its almost certain to be there
  14. #14 Re: what is this ticking noise?!?!?
    michigan
    I've ran seafoam before with no issues. Also fixed my lifter tick too. Good luck!
  15. #15 Re: what is this ticking noise?!?!?
    Crappy should have it.
    Same with Partsource.
    Also Napa.
    Try in that order because they're arranged from best price to worst.
  16. #16 Re: what is this ticking noise?!?!?
    Apr 2011
    sudbury
    Ok i founs some and tried it . Still ticking .. Used a screw driver and only thing i hear ticking is the injectors
  1. Lifter/ticking noise???
    By kind153 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-24-2010, 12:43 PM
  2. Ticking noise, thinking lifter
    By bradford82 in forum General Tech Discussion
    Last Post: 01-25-2009, 10:44 AM
  3. Ticking
    By theboss98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2009, 01:17 PM
  4. ticking noise???????
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 10-02-2008, 12:27 PM
  5. weird ticking noise coming from turbo
    By lilredss0287 in forum Turbo
    Last Post: 09-05-2008, 08:56 PM
