Thread: header install ?'s
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 62
  1. #1 header install ?'s
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    well ive been searching and i havnt been able to come up with anything. im about to buy SD header kit. its going on my 97, any tips i should know about or maybe pointed towards a how to thread. as it sits, this kit will be getting rid of my cat so will i need an 02 sim or an extension? my engine mount is shot, would be recommended to replace that first? thanx for any advise.
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  2. #2 Re: header install ?'s
    Omaha, NE
    A lot of people use speed daddys. Upgrade the gaskets and clamps and you'll be good to go. You can weld in an 02 bung if you need it, but I think it comes with one iirc.
    For the motor mount, ZZP and WBS have poly mounts.
    I hope that gets you in the right direction.
  3. #3 Re: header install ?'s
    Florida
    Yeah, the Speed Daddy headers come with front and rear o2 bungs, and a rear o2 plug.
    For the motor mount, you can get a solid one (no leaks) from your auto parts store for like $50, and they have a lifetime warranty.
    You will need an o2 extension for the front o2 sensor
    ZZ Performance
    it says 04+ but it works fine on mine.
    heres a write-up
    http://www.grandprixforums.net/speed...eup-32920.html
    get band clamps, and use lots of RTV.
    I reused my stock exhaust gaskets, and they sealed fine.
  4. #4 Re: header install ?'s
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    ive done 3 sets of sd headers myself, make sure b4 you put them on u insert the crossover pipe to make sure it goes in right, you need to upgrade to band clamp, i believe 2 3" and i believe 2 2 1/4" band clamps are needed. also small problem may occur with the front o2 sensor, u may need to bend or dent the place on the firewall where the o2 mounts into the header, not alot of room, also i would recommend install of the o2 b4 you mount the header. also obviously you start with the back one first, you can leave the bolts loose or tighten them all the way. you will have to rock that engine forward all the way to get that rear header in place, its better when the heads are off! good luck
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  5. #5 Re: header install ?'s
    Nov 2010
    south east AZ
    thanx for the tips and that thread.
    01 T/A WS6-SOLD
  6. #6 Re: header install ?'s
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    If you can, get the downpipe welded because the slip-joint on my car slipped out and my car was running open downpipe. Luckily i have a friend who welds!
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  7. #7 Re: header install ?'s
    Florida
    Open downpipe is boss.
    I drove around for about a week, open DP, just cause it sounds nice...terrible at anything over like 1000rpm tho...lol
  8. #8 Re: header install ?'s
    Wilkes Barre, PA
    Oh yea i know lol i love the idle but once you hit that gas its like... no.. wtf lol but it shakes the whole damn car!
  9. #9 Re: header install ?'s
    Charles City, IA
    or you just clamp the dp with regular clamps and it will not come apart.
    SMGPFC Two Nipple General
  10. #10 Re: header install ?'s
    I find with my car now shifting into fourth stupidly low (37 mph) that I really hate the sound of the engine at 1200 RPM under load..... its just bad.
  11. #11 Re: header install ?'s
    Nov 2010
    south east AZ
    with headers?! coming from an ls, if it shakes the car while ideling, i have a smile. when you rev it, and neighbors look out their doors thinking its a drag car, i have a smile. when i drive around and the exhaust drowns out the stereo, i have a smile. curious as to how a v6 will sound with headers
    01 T/A WS6-SOLD
  12. #12 Re: header install ?'s
    Wilkes Barre, PA
    well thats with open downpipe lol
  13. #13 Re: header install ?'s
    Nov 2010
    south east AZ
    this whole forced induction thing and especially anything smaller then a v8 is new to me. this gp is my fourth car and fourth pontiac, the first three were trans ams. the first t/a was a third gen with a 305 and 5 speed, the other two were 4th gen's with 6 speeds
    01 T/A WS6-SOLD
  14. #14 Re: header install ?'s
    its a transverse 3800.
    you wont like it.
    The car goes fast, makes epic whine.
    that is all.
  15. #15 Re: header install ?'s
    Nov 2010
    south east AZ
    ah, open headers makes you yell to be heard
    01 T/A WS6-SOLD
  16. #16 Re: header install ?'s
    Nov 2010
    south east AZ
    ya its a deff change from RWD with monster tq. not quite the same neck snap or as fast lol buts fun and interesting. learning something new with this car
    01 T/A WS6-SOLD
  17. #17 Re: header install ?'s
    your car makes 280 ft lbs at the crank.
    If your T/A made that you wouldn't have been impressed with it either
  18. #18 Re: header install ?'s
    Nov 2010
    south east AZ
    give me a 4th gen with an ls and i can take it apart and fix just about anything or pinpoint what is wrong with it, kinda like alot of guys on here with their cars, once you get to know your car you wanna know more
    01 T/A WS6-SOLD
  19. #19 Re: header install ?'s
    MA
    just so you know, these engines sound horrible, the only good noises are cammed lopey idle and s/c whine.
    SMGPFC Member #9
  20. #20 Re: header install ?'s
    Nov 2010
    south east AZ
    lol, 410 whp 390 wtq, get that and multiply it by 15%, add that total to the original number and get the crank number.
    01 T/A WS6-SOLD
  1. TOG header install
    By 2001goldGTP in forum General Tech Discussion
    Last Post: 12-16-2010, 11:17 AM
  2. SD Header Install Soon...
    By theshznt69 in forum 04+ Specifics
    Last Post: 05-23-2010, 05:28 PM
  3. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  4. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
  5. OBX Header Install is Done!!
    By Uno99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:43 PM
