Thread: inspection problem
Results 1 to 10 of 10
  1. #1 inspection problem
    GTX Level Member kingd44's Avatar
    Feb 2008
    newyork
    i bought a pcm from will at overkill a while ago........ i havent been able to inspect my car in over a year and a half now wich means i cant get a registration cause it need to be inspected first...... i contacted will and told him this and i payed him more money to send me another one.....well this one hasnt worked either and he stopped answering my emails.... ive taken it to 4 diff inspection places and they have no idea whats wrong...it wont connect to the state inspection machine....has anybody ever had this problem or have any idea what i can do about it cause i keep getting pulled over and getting tickets
    180 t-stat, wizaired cai, s&s headers, 3inch cat back exhaust,jpg plug wires, auto lite plugs, 3.4 pulley, and ovk pcm......rockers to come............next summer might go intercooled
  2. #2 Re: inspection problem
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Maybe the OBD2 ports bad under your dash.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: inspection problem
    Omaha, NE
    What can't they connect to? I'm confused by the OP.
  4. #4 Re: inspection problem
    Feb 2008
    newyork
    i took it to my friend who works for good year and he was able to get it to connect for like 10 secs but then it stops.... how can i check if OBD2 ports bad....ive gotten the car inspected b4 i bought this pcm but havent been able to since ive had it
  5. #5 Re: inspection problem
    Omaha, NE
    I think its because Will (overkill) locks his PCM's. I would suggest picking up a stock pcm and using that for the inspection instead.
  6. #6 Re: inspection problem
    Feb 2008
    newyork
    well i got in touch with will and i bought a stock pcm from him and he knew i couldnt get it inspected and now hes not answering my emails so im stuck with a tuned pcm and stock pcm and neither of them connect
  7. #7 Re: inspection problem
    Omaha, NE
    Do you know anybody with HPTuners or DHP? Maybe your vats (security) is off...
  8. #8 Re: inspection problem
    Feb 2008
    newyork
    no....i called a place by me called no limit cause i know they tune cars and they acted like they had no idea what i was talking about..... i feel like a normal mechanic should be able to tell if my ports are bad right? idk how i would tell if my security is off cause i dont live by any one wit a tuner
  9. #9 Re: inspection problem
    Houston
    I cant get mine inspected either. I had to pull my battery to change the alternator and it reset the comp. Apparently I need to put 2000 miles on it before it will pick up all my systems. I maybe put 2000 miles on it a year.
  10. #10 Re: inspection problem
    Pennsylvania
    Nope, I've seen Overkill's tunes pass inspection fine.
  1. Anyone else have this problem?
    By PMave in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2009, 08:09 PM
  2. passed inspection with a smokey car
    By Damojo2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2009, 08:30 AM
  3. Passing Inspection
    By blueguy in forum General Tech Discussion
    Last Post: 02-22-2009, 11:52 PM
  4. Inspection/Parking Brake light on
    By c002529 in forum Brakes/Suspension/Chassis
    Last Post: 01-25-2009, 10:41 PM
  5. Help with a Pennsylvania Inspection
    By JoshMcMadMac in forum Off Topic Discussion
    Last Post: 12-24-2008, 11:36 AM
