Thread: 97 l32 camaro
Page 6 of 8 FirstFirst ... 45678 LastLast
Results 101 to 120 of 160
  1. #101 Re: 97 l32 camaro
    although im still getting use to the 4th gen. iv owned several 3rd gen camaro's and firebirds and have built them from the ground up. i know every nut and bolt in them and im almost that way with this 97 lol.
    do you have any sort of instant messanger ?
  2. #102 Re: 97 l32 camaro
    Never Never Land
    we have a chat on the index page...or you can post stuff on his page...or private message him..i havea 97 RS also lol
  3. #103 Re: 97 l32 camaro
    Troy OH
    Quote Originally Posted by 97RS View Post
    no cam just a stock l32 with 20k miles off a 06 GTP, i really would hate to cam it since the motors in the car and rockers would also be a ***** to do buts its doable when i install the intercooler. im really looking to get the most mpg while dailying and the most power when at the track. i know power and fuel millage don't go together. since im not familiar at all with these engine and how they respond from the looks of it u think 1.9 rollers rockers, good springs and intercooler and a 3.1 pulley would be a good set up? or are the rockers going to help me much or should i just invest that money in 42.5 lb injectors and go lower on boost? i have headers and a CAI already.
    rockers aren't that bad, just pop the valve cover gaskets off.
    i've heard that add a pretty decent amount of power as well. my best advice would probably be to not really guess at the pulley size until you're ready to tune. an intercooler is going to give you a lot of freedom when it comes to your boost level, the m90 is notorious for high temps. it's what's really going to let you get away with going lower than a 3.4" if you keep stock rockers. if you decide to go with 1.9 rockers, do your research on springs to go with it, and then maybe start tuning with as big as a 3.4" or a 3.25" and work towards a 3.1". it should run that small of a pulley, it really is all in the tune though.stock injectors might be getting starved at that point, so an upgrade probably wouldn't hurt, but that will hurt gas milage. if you keep stock rockers and springs, you might be able to get away with a 3.25 with the intercooler
  4. #104 Re: 97 l32 camaro
    Feb 2009
    flintnasty MI
    You meant help gas mileage right?
  5. #105 Re: 97 l32 camaro
    Help it like a boss
  6. #106 Re: 97 l32 camaro
    SE Level Member 97RS's Avatar
    Dec 2010
    miami fl
    lol what bigger injectors would waste more gas when tuned and the car in not in boost? i could care less at the amount of gas it waste when im at the track, but i do care about how much it does waste on the way to work,movies, beach, and my girl friend's house. thats why i was planing on useng a stock pulley when daily driving and then dropping to when ever i go to the track. 350 rwhp is my goal lmk on what setup to go with. stock injectors and 1.9 rockers or 42.5 injectors with stock rockers. sorry for asking to much but im confused and im getting the car dyno tuned when i install everything.
  7. #107 Re: 97 l32 camaro
    bigger injectors dont mean youll waste gas. that is why you tune for them...
  8. #108 Re: 97 l32 camaro
    you're going to need a cam to get that much power out of an M90.
  9. #109 Re: 97 l32 camaro
    Feb 2009
    flintnasty MI
    350whp is near impossible for you short of a xpz cam, intercooler, and someone that knows what they are doing tuning wise.... Probably going to struggle to do this on 93 octane as well.
    in better news, you can run huge injectors and a tiny pulley, and still get 30mpg on the highway. If you dont trust your foot, you can enable the bbv to never close, and you wont make more than 2 or 3 psi.
  10. #110 Re: 97 l32 camaro
    Dec 2010
    miami fl
    alright, so im going to try to see what i end up with on a 3.1 pulley and stage 2 intercooler. if im not satisfied then i'll see about buying a cam and injectors.
  11. #111 Re: 97 l32 camaro
    ATX
    having been in a bolt on tune 3800 camaro, with a T5 and a posi 3:42 gear out back. I must say it was a enjoyable car to ride along in. Having a supercharger on one would be great fun. Just get a really good tune on it and you should enjoy your ride and get good mpg.
    and if you havnt done it already i highly suggest a posi and some gears out back!
  12. #112 Re: 97 l32 camaro
    3.42 is kinda weak IMO if its not a DD.
  13. #113 Re: 97 l32 camaro
    Dec 2010
    miami fl
    my car has the performance option. i have a 3.23 posi rear end with disk brakes.
  14. #114 Re: 97 l32 camaro
    Dec 2010
    miami fl
    anyone running a 3.1 pulley, intercooled, and header set up on here? any whp numbers?
  15. #115 Re: 97 l32 camaro
    300. Maybe. But your not coming close to, or passing that without rockers or a cam.
  16. #116 Re: 97 l32 camaro
    Dec 2010
    miami fl
    i need to switch out the valve covers anyway to make the oil inlet on the passenger side, how much more hp will the 1.84 rockers give me in my set up and will it effect daily driving mpg? i've installed 1.6 roller rockers before on my lt1 and noticed a performance gain but didn't bother to see how it effected mpg. thanks for the input man and ive read your write up but i keep getting lost. its 20 more or less hp on a stock motor or 20 hp on my application? and why would you have to rev over 6k if peak hp is at 5200 on a stock cam? thanks for the help guys
  17. #117 Re: 97 l32 camaro
    Never Never Land
    pretty sure you dont HAVE to rev to 6K...but if you do youll probably need new springs. With 1.9's you will if reving past 6K.
    Pretty sure someone on here said rockered cars can do 30ish highway.
  18. #118 Re: 97 l32 camaro
    Dec 2010
    miami fl
    aightttt
  19. #119 Re: 97 l32 camaro
    with 1.9 RR's you'll find your power band is very flat.
    But you'll be stuck under 300 WHP.
  20. #120 Re: 97 l32 camaro
    ATX
    get a aluminum driveshaft from a ls1. It will help you with your goals and can be had for cheap.
  1. LT1 Camaro
    By ls1camino in forum Track Sessions and Kills
    Last Post: 11-21-2009, 02:14 AM
  2. Camaro vs Evo
    By SlowM90 in forum Track Sessions and Kills
    Last Post: 08-30-2009, 03:26 AM
  3. Camaro
    By bloxmagic in forum Track Sessions and Kills
    Last Post: 07-03-2009, 02:09 PM
  4. Best Camaro EVER!
    By J GTP in forum Off Topic Discussion
    Last Post: 06-25-2009, 07:00 PM
  5. GXP VS New Camaro
    By Black GXP in forum Track Sessions and Kills
    Last Post: 06-23-2009, 01:23 AM
