Thread: spark plugs
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 79
  1. #1 spark plugs
    Nov 2010
    Atlanta Ga
    What plugs should I use. Top swap,headers,vs cam, ported blower
  2. #2 Re: spark plugs
    autolite 104's
  3. #3 Re: spark plugs
    Charles City, IA
    104s
    SMGPFC Two Nipple General
  4. #4 Re: spark plugs
    SE Level Member 1998DaytonaPaceCar's Avatar
    Dec 2010
    Lawton / Fort Sill, OK
    is autolite part # 606 the right ones thats the ones they have on the autozone website
    1998 Daytona Pace Car #1371 of 1500
    Mods: Pacesetter headers, 3.4" S/C pulley, 180ยบ t-stat, K&N FIPK Intake kit, Cross drilled rotors, 18" rims, DHP PCM, Custom exhaust (Cherry Bomb glasspack acting as resonator, 2X Corsa sport mufflers from my old 06 GTO R.I.P.)
  5. #5 Re: spark plugs
    Pennsylvania
    Quote Originally Posted by 1998DaytonaPaceCar View Post
    No. 606 is stock heat range. He should probably be dropping heat ranges (might be 605, might be 104, depending on his S/C pulley) because of his modifications.
  6. #6 Re: spark plugs
    GTX Level Member real diehl's Avatar
    Salina, KS
    NGK TR6's
    signature removed for inappropriate content.
    -bio
  7. #7 Re: spark plugs
    what pullay?
    If you're sticking with the 3.8 then 104's are fine.
    3.4-3.6 area you might want to consider tr6's.
    possibly 103's if you're going to push 3.4 or smaller.
    Note I say consider.
    I've run both TR6's and 104's with my stock pulley and the plugs ARE too cold for the boost level. But I'd rather not try 605's, instead i'm going for more boost.
  8. #8 Re: spark plugs
    GT Level Member TheAce144's Avatar
    Dec 2010
    Montreal, Canada
    I personnaly use the NGK Iridium IX on my car, doing the job really good and they are long lasting...It's a pain in the ass to change plugs!
    04 GTP CompG: SSAC Headers, 3.6" Modular Pulley System, Autolite 104, NGK Spark Plug Wires, CAI, ZZP 180 T-Stat, Overkill PCM (Custom Street Tuning By Will), Goodyear Eagle F1 Tires, Hawk HPS Brake Pads, Magnaflow Magnapacks 4", SE Front Fascia
    Check Out My Car! ---
  9. #9 Re: spark plugs
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by TheAce144 View Post
    false
    02 GTP with mods 05 GP for DD
  10. #10 Re: spark plugs
    with headers its a joke
  11. #11 Re: spark plugs
    Jul 2008
    even without... its not that hard.
  12. #12 Re: spark plugs
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    103's forsure
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  13. #13 Re: spark plugs
    Hagerstown,Md
    Youre also stock for the most part. Copper plugs FTW. It takes me under 10 min to change my plugs....
  14. #14 Re: spark plugs
    Dec 2010
    Montreal, Canada
    Quote Originally Posted by 01gpgt01 View Post
    1) You are absolutely right, for "almost" a stock setup like mine copper plugs are the best...
    2) Since I live in Canada and I don't have access to a garage, I preferred using Iridium since they will last way longer
    3) How did you do it under 10 mins? I bought my car used and I changed them when the car reached about 40K...They were completely jammed inside the metal retainers and the wires broke in my hands...It took me around 2 hours just to do the three in the back...any tips or tricks for my next spark plug change?
    Thanks
  15. #15 Re: spark plugs
    1) an intake and a tune does not qualify for modded.
    By modded we mean smaller than stock pulley with the things that come with that.
  16. #16 Re: spark plugs
    Dec 2010
    Montreal, Canada
    Weird because in your signature you promote a thread, and in this thread a CAI is mod 2 and and reprogrammed PCM is mod 7
    IMO, any upgrade over bone stock is considered a mod, whatever gain they provide...
  17. #17 Re: spark plugs
    I would love for you to see the cabin of my car.
  18. #18 Re: spark plugs
    SE Level Member HtxGP's Avatar
    H-town
    Do i need to gap the 104's ? I'm getting the 3.4 pulley real soon. Is it ok to change the plugs first?
  19. #19 Re: spark plugs
    Pennsylvania
    Quote Originally Posted by htxgp View Post
    do i need to gap the 104's ?
    yes
    i'm getting the 3.4 pulley real soon. Is it ok to change the plugs first?
    no
  20. #20 Re: spark plugs
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Quote Originally Posted by SlowNA06 View Post
    yes
    no
    How would we know where to gap them at? Im a beginner at this too. I have never changed my plugs before and i want to try to learn how so i can save myself some money.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  1. spark plugs
    By Biggie1720 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2010, 10:49 AM
  2. Spark Plugs?
    By gahris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2010, 03:13 PM
  3. Spark plugs
    By Chleby in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-16-2009, 10:43 PM
  4. spark plugs
    By NEONNIGHT34609 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-07-2008, 09:43 PM
  5. Spark Plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2008, 10:45 PM
