AC Declo Iridiums. Burn hot enough for what you're doing and are correct to the vehicle. Will run better then putting autolites in them. Autolites are OEM to Ford not GM, don't use them. They are a waste of money, if you're going to do it, do it doi it right. I get my information from a guy who has been a mechanic for 33+ years and has college's begging him to teach there automotive courses.
Maybe he needs to be educated in the 3800 platform since Autolite plugs are PROVEN to get things done on these cars.
I run AL103R's in mine. Gap 'em at .055".
Dare we find out what the TTGT runs?
I dare YOU.
I haven't changed my AL 104's in a year or so. I've put over 10k on them too. No problems. I plan to change them next oil change though.
put in the AL 104's last weekend, my car loves them
+1 on about 10-15 min to change out all 6
So I had some free time this afternoon after work, pulled my plugs and checked them.
They've got right at 10k on them, all colors were good, so I know I'm running about the right afr.
Plugs were gapped at .055 when the motor was put in, and I measured all of them, the smallest gap was .058, and the biggest one was at .060. Re-gapped them, and put them in to see what they look like after the next oil change.
So Autolite is the way to go? I am also going to change my spark plugs. 103s or 104s?
go 605's, slightly cooler, but just by a smidge over the 606's.
btw, 606's is stock range, 605's slightly cooler, 104's and 103 are for more modded cars.
I don't know where this autolite crap is coming from. everyone i know around here runs AC Delco Iridiums. Everyone I've sold plugs to for these cars gets AC Delco Iridiums, they won't put those useless pieces of crap in there car. You want the best opinion on plugs go talk to a mechanic, a circle track racer, or drag racer(I mean real cars not ricers). Seriously, do it right and don't waste your money on autolites. That's basically putting 6 turds into your cylinder heads.
you get a heart for that post.
Because it was worth its weight in air.
Autolite's are proven...this is like the 2nd post you have flaming them...your dealing with old technology and Autolite's are PROVEN in these cars...maybe I should use a hotter, useless factory plug like a ACDelco in a modded car that NEEDS a colder range plug.
Oh and yet AC Delco makes colder burning plugs as well. I just know taking the Ford product out of my GM car and putting GM plugs back in it gave it better performance all around.
I didn't think honeywell was owned by ford these days.
i run autolites in my gtp and acdelco in my caddies, and i did have the iridium plugs in my first gtp(26 bucks a plug) and the cheap plugs did just fine, i ran them in silvermistchick's gtp and felt better throttle response. copper ftmfw
