Thread: Speed Daddy Headers on
Results 1 to 20 of 26
  1. #1 Speed Daddy Headers on
    Nov 2009
    MN
    Spent several days last week getting the speed daddy headers onto my 04 GTP Comp G. I only had to bend the A/C line down 1/2 inch. That was all it took to get the headers in and sealed. The O2 sensor comes pretty close but has some room to play. Just in case I am beating in this section of firewall but have been fine without doing so. Maybe I got a lucky set of speed daddys but these fit very well and no issues/leaking or ticking with them. I wrapped the front middle header tube because it comes close to A/C Line & Front fan motor cover.
    Here is a vid of my install. Since then I've put back on my heat shield for intake, and painted some engine components.
    YouTube - video-2010-12-31-11-54-34.mp4
    Enjoy!
  2. #2 Re: Speed Daddy Headers on
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Interesting way to run the plug wires. looks good. Ive had mine for about 5 years. There good headers
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Speed Daddy Headers on
    Nice.
    Any reason why you wrapped the first primary? Wrapping Stainless steel isn't a great idea from what I've heard.
  4. #4 Re: Speed Daddy Headers on
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    I think he was worried about it being so close to plastic shroud on fan.
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  5. #5 Re: Speed Daddy Headers on
    Nov 2009
    MN
    Nice.
    Lol, well if you read the original post......
    Jk, I skim read other peoples posts too!
  6. #6 Re: Speed Daddy Headers on
    Charles City, IA
    just bend the ac line more.
    SMGPFC Two Nipple General
  7. #7 Re: Speed Daddy Headers on
    Who reads?
    I bent the A/C on an Impala to make it work...its just the A/C...who cares.
  8. #8 Re: Speed Daddy Headers on
    He'll be flipping the sway bar soon. There's a slight rubbing of exhaust in reverse.
    Yeah guys..I'm that good.
  9. #9 Re: Speed Daddy Headers on
    i flipped mine before i did headers because i knew it was going to happen.
  10. #10 Re: Speed Daddy Headers on
    Mines nowhere NEAR the sway.
    in fact, its damned close to the tunnel itself.
    Lookin good.
  11. #11 Re: Speed Daddy Headers on
    Hagerstown,Md
    X2 mines like matts
  12. #12 Re: Speed Daddy Headers on
    Nov 2009
    MN
    WRONG! lol.
    The speed daddys are not touching the sway bar, like others have stated, much closer to the tunnel itself then the sway bar. I used air hammer, beat in tunnel for O2 sensor, however still have some crap going on with applying gas while in reverse.
  13. #13 Re: Speed Daddy Headers on
    Ok.. don't believe me. I'm the one that's answering your post on the other forum... This isn't a motor mount, it's not a dipstick tube....lol The guys that said that are H body guys..
    BTW I tossed up pics of one of the SD installs I did. You are probably rubbing the O2, but I believed that you pounded the firewall enough to keep that from touching.
    Hmmm hold on here, having another thought of my mental stability. Reverse should lift the back of the motor up, meaning the piping could hit the tunnel, not sway.
  14. #14 Re: Speed Daddy Headers on
    Charles City, IA
    Yup it kicks up up into the tunnel and makes it sound like your trans just chewed up some gears and spit them up.
  15. #15 Re: Speed Daddy Headers on
    Nov 2009
    MN
    Well assuming without cutting there isn't much hope if the headers are going up into the tunnel when in reverse. Maybe some poly mounts would stop the engine from moving all together, or no?
  16. #16 Re: Speed Daddy Headers on
    Feb 2008
    might be worth a try, there would be less play to rock back and forth at least
  17. #17 Re: Speed Daddy Headers on
    Nov 2009
    MN
    I'll have to give it a shot.
    04 GTP Comp G/Inferno Package/PFYC Tips/K&N Custom Intake/AL104's/
    180*/ S/D Headers /3.6" MPS /Tuned/Aeroforce Interceptor
    My old 02 GT http://img.photobucket.com/albums/v3...9/DSCI0182.jpg
  18. #18 Re: Speed Daddy Headers on
    GT Level Member donmega's Avatar
    St louis, mo
    I have sd headers and for whatever reason the o2 snsr is off to the right hitting the firewall causing mad vibration. so i just took a block of wood and a hammer dented the firewall in so the 02 snsr doesnt touch. once in a while ill get vibration but i assume its from everything moving the exhaust slightly that the o2 sns hits the wall once in a while. The vibration is DEFINITLY the o2 snsr hitting the firewall though not an engine mount.
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  19. #19 Re: Speed Daddy Headers on
    St louis, mo
    if i were to do it again id take the rear manifold to a machine shop b4 installing it have them make a new o2 hole on the top or a better location(i know theres not much room) and plug the old one.
  20. #20 Re: Speed Daddy Headers on
    I have one on the crossover.
  1. Speed Daddy Headers
    By ctrout in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2011, 10:37 PM
  2. Speed daddy Headers...
    By Vlad0691 in forum General Tech Discussion
    Last Post: 01-17-2011, 01:09 AM
  3. speed daddy headers
    By PONTIACGTP05 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 10:54 PM
  4. Speed Daddy Headers
    By Advan22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2010, 12:06 AM
  5. Speed Daddy Headers
    By Vioarr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2010, 03:29 PM
