Thread: zzp throttle body spacer
Results 1 to 8 of 8
  1. #1 zzp throttle body spacer
    SE Level Member samuelcb409's Avatar
    Galveston, Texas
    do they make any difference and i had one installed and recently noticed a coolant leak under throttle body spacer from 1st gasket installer did not use any gasket sealer just gasket, could that be the cause or do they all leak please help me out asap
    MODS: 3.0 MPS, CAI, SD Headers w/Custom 3"DP, 160* T-Stat, NGK TR6, Full Size intercooler, #42.5s, Ported LIM & Gen III, LS1 TB w/85mm MAF , s1x Cam, #90 Springs, Intense Pushrods, EGR Delete, Cat and U Bend Delete, Magnaflow Resonator & Mufflers, Fully Built ZZP Trans, 2800 stall Tuned by KHP Peformance
  2. #2 Re: zzp throttle body spacer
    tb spacers are fail.
    they can cause leaks.
    only good for Meth or NOS users.
  3. #3 Re: zzp throttle body spacer
    Galveston, Texas
    so no matter what it will leak??
  4. #4 Re: zzp throttle body spacer
    no, you can get them to not leak with a good gasket.
  5. #5 Re: zzp throttle body spacer
    Galveston, Texas
    would gaskets from auto parts stores and gasket maker do?? or would i have to get better gasket from zzp or performance site??
  6. #6 Re: zzp throttle body spacer
    just take it off. it's not helping you at all and it just leaves you open to intake leaks and higher rear head temperatures because of the decreased coolant flow through the throttle body.
  7. #7 Re: zzp throttle body spacer
    Galveston, Texas
    also do the studs and nuts have to be tightened or torque to a certain lbs
  8. #8 Re: zzp throttle body spacer
    Sell it.
  1. throttle body spacer
    By Lougp05 in forum Off Topic Discussion
    Last Post: 09-18-2010, 11:44 PM
  2. Throttle body spacer
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2010, 08:21 PM
  3. throttle body spacer
    By danross in forum General Tech Discussion
    Last Post: 02-19-2009, 06:40 PM
  4. Throttle Body Spacer
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2008, 06:21 PM
