Thread: Spark Plug tips gone!!! UPDATE 2/6/2011
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 112
  1. #41 Re: Spark Plug tips gone!!!
    Banned
    Sioux Falls, SD
    will it make them look like ****?
  2. #42 Re: Spark Plug tips gone!!!
    GT Level Member glanzergtx's Avatar
    Dec 2008
    Sioux Falls,SD
    Quote Originally Posted by miker56 View Post
    Well if you install them and put the RTV on them like a 2yr yes they will look like ****....
    This my take some work but i would recommended getting rid of that stupid Downpipe that comes with these headers and try to go this route. In some way shape or form.
    Just your normal 730whp 4dr family car.
  3. #43 Re: Spark Plug tips gone!!!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    What heat range plug did you have in? Id run 103's or 104's in it
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #44 Re: Spark Plug tips gone!!!
    Dec 2008
    Sioux Falls,SD
    Quote Originally Posted by 01gpgt01 View Post
    he HAD.....stock ac-delco plugs in it. He now installed 605's for the time being.
  5. #45 Re: Spark Plug tips gone!!!
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    when i 1st got my car i had a misfire and come to find out the tip on cyl. #4 was gone. but i have no damage to the engine from what i know. he may not have damage. u never know
  6. #46 Re: Spark Plug tips gone!!!
    It's always nice to hope...but with no flow mods and high compression...I highly doubt it.
  7. #47 Re: Spark Plug tips gone!!!
    Hagerstown,Md
    Pull the plugs and put 103's in it, and hope that the damage was just isolated to plug. Id have a shop bore scope the effective cylinders and see if the piston looks like a dog chewed on it
  8. #48 Re: Spark Plug tips gone!!!
    But heat really doesn't cause that kind of damage really...something has to physically cause that damage...
    Bookmark this...best plug images to date.
    http://blog.carlist.my/wp-content/up...park_plugs.jpg
  9. #49 Re: Spark Plug tips gone!!!
    Waterloo, Iowa
    well yea i understand his reason since he didnt have flow mods but i did. idk where the tip went off my spark plug. maybe ill find it when i pull the motor lol
  10. #50 Re: Spark Plug tips gone!!!
    You won't find it...it'll be burned up in the combustion chamber...what you will find...is a chunk of your piston missing.
  11. #51 Re: Spark Plug tips gone!!!
    Waterloo, Iowa
    maybe the spark plug just got dropped and the piece broke off outside the engine lol. i will never know since i bought the car with a misfire and it was that simple spark plug fix
  12. #52 Re: Spark Plug tips gone!!!
    Banned
    Sioux Falls, SD
    I just hope its not as bad as some of you say
  13. #53 Re: Spark Plug tips gone!!!
    Hagerstown,Md
    judging by the fact you had stock plugs in there. Im afraid it prob isnt good
  14. #54 Re: Spark Plug tips gone!!!
    Banned
    Sioux Falls, SD
    well im ready for the worst. But if i do need a new block should i get another l26 or a l32
  15. #55 Re: Spark Plug tips gone!!!
    Largo, Florida, United States
    extremely good link nick.
  16. #56 Re: Spark Plug tips gone!!!
    Banned
    Sioux Falls, SD
    So i am planning on the worst case Here are my new plans
    1. Used L26 Bottom end
    2. either s1x or xp cam
    3. 110# Crow Springs
    4. Double roller timing chain
    5. SD Headers
    Any imput would be greatly appricated, i am on a budget!
  17. #57 Re: Spark Plug tips gone!!!
    Skip the double roller honestly...you REALLY don't need it. You can get Crow 105's which what I'm guessing your talking about...OR...get a VS cam and use the factory valvetrain. Just a few options there. If you do get the Double Roller...the crank gear will have to be machined down so it doesn't crack or make contact with the oil pump cover
  18. #58 Re: Spark Plug tips gone!!!
    Banned
    Sioux Falls, SD
    isnt that the part you remove
  19. #59 Re: Spark Plug tips gone!!!
    What?
  20. #60 Re: Spark Plug tips gone!!!
    Banned
    Sioux Falls, SD
    nevermind thats the balance shaft you remove
  1. Spark Plug Help
    By STP5593 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 10:15 PM
  2. Spark plug suggestions?
    By projectGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2009, 08:43 AM
  3. New Spark Plug sugggestions
    By RichCresci in forum General Tech Discussion
    Last Post: 08-25-2008, 08:32 PM
  4. Spark plug issue?
    By TurboKent in forum General Tech Discussion
    Last Post: 04-12-2008, 03:07 PM
