crossover is fixed and yeah -20 psi.
Is it 20psi...or -20...because the negative value is the vacuum...which is right for a non-cammed car.
So...whats the issue with the boost then?
i was just stating my psi is back to normal, but at WOT i can only reach 7 psi. nothing more not 7.1 nothing higher at all.. is this a BBV or a vacuum leak i havent i time to check so i figured id check around first.
Aren't you on a 3.5" or 3.4"? With headers that's about normal...you don't want higher boost honestly...lower boost levels means it is flowing right.
Sounds like you had a whale climbing on top of your engine and breaking all your chit!
So is your car running much better now with no issues or is it still bogging down? When I installed my speed daddy headers I had none of these issues.
Lol I bet next time op will work on his own car.
