Thread: AC compressor Clutch Problem
Results 1 to 4 of 4
  1. #1 AC compressor Clutch Problem
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Hey all,
    I have a problem with my air conditioning. When I turn the AC off the clutch on the compressor stays engaged. Only way I can get it to disengage is to take the diode out of the fuse box. My old diode was cracked and I bought a replacement but it still does it. Another thing I noticed yesterday was after running my car for about 1 minute, I went to take the diode out and it was hot as hell! I couldnt even hold it in my hand it was so hot. So im guessing whatever activates that diode is messing up. Any ideas?
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  2. #2 Re: AC compressor Clutch Problem
    Bastard Reptile's Avatar
    Kansas City, MO
    Kind of sounds like the switch in the dash is bad.....or maybe the relay is sticking.
  3. #3 Re: AC compressor Clutch Problem
    Feb 2008
    Houston
    Thanks.........it doesnt matter. I wrapped my baby around a pole being stupid the other day.
  4. #4 Re: AC compressor Clutch Problem
    Kansas City, MO
    Quote Originally Posted by t24moore View Post
    Ouch man....that's sad to hear. Well.....not to be a vulture or anything, but if you get to take anything off of her....keep me in mind.
  1. replacing bad ac compressor?
    By fst in forum Off Topic Discussion
    Last Post: 07-23-2010, 07:51 PM
  2. What is the problem?
    By spidamanSS in forum General Tech Discussion
    Last Post: 05-07-2008, 12:56 AM
  3. Pieces of clutch material on my magnet...
    By copgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-26-2008, 06:36 PM
  4. 4th gear clutch hub install
    By CT Tech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-06-2008, 11:03 PM
  5. AC compressor is causing my RPM to surge?
    By JCGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2008, 01:48 PM
