Thread: Service Engine light flashes... engine shakes...hardly any power at all
Results 1 to 8 of 8
  1. #1 Service Engine light flashes... engine shakes...hardly any power at all
    Dec 2010
    lower burrell, pa
    Hey everyone, new here, lookin for some help for my 2000 grand prix gtp s.c. 3.8. I got about 130K on it and the service engine light has been on for quite a while now. Anyhow the other day my engine just started shaking like crazy and the service engine light started flashing, my car has absolutly no power(can barely make it up hills), smells like its running rich. I checked all the plugs and changed the wires then ran the codes on it. I was getting a MAF sensor when i did....could this be whats causing the loss of power and ridiculous shaking? I'm picking up a new one tomm but just looking for any and all help that might be out there.
    thanx in advance
  2. #2 Re: Service Engine light flashes... engine shakes...hardly any power at all
    Delaware, OH
    Flashing engine light means its a potentially damaging code. I'd get it into a shop to get checked out before driving again. Could be anything from a severally clogged cat to a bad cylinder.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  3. #3 Re: Service Engine light flashes... engine shakes...hardly any power at all
    Guessing an injector. I think in the manual it will say if the SES light flashes x number of times in a row it is a certain thing.
  4. #4 Re: Service Engine light flashes... engine shakes...hardly any power at all
    Pennsylvania
    Squirrel chewed through one of my injector wires once.
    Made my engine breakdance in the bay.
  5. #5 Re: Service Engine light flashes... engine shakes...hardly any power at all
    Dec 2010
    lower burrell, pa
    ended up figuring it out.....still pullin a few codes but its runnin a wholeee lot better....i pulled the front 3 plugs out and checked compression in each and wasnt getting any in cylinder 1. pulled the valve cover off and found out i had snapped a valve spring. called around to about 6 different places till i found one (for only like 6 bucks). pain pushin that spring down and gettin those clips back on but that solved just about everything. i still think i need a new MAF sensor but at least i can do work now hahaha..thanx to all for your help everyone
  6. #6 Re: Service Engine light flashes... engine shakes...hardly any power at all
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Well you found the issue, but a Flashing CEL is Misfire issue. Surprised the Valve didnt drop and get boogered up
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  7. #7 Re: Service Engine light flashes... engine shakes...hardly any power at all
    Dec 2010
    lower burrell, pa
    couldnt that broken spring have been the issue with the blinking CEL...btw its not blinkin anymore...need to pull codes again its still on...either needs reset or its my MAF sensor
  8. #8 Re: Service Engine light flashes... engine shakes...hardly any power at all
    Hagerstown,Md
    Yes the dead cylinder was misfiring. Sorry to confuse you. But the dead cylinder missing caused the CEL to flash.
  1. Pours blue smoke, wont idle, check engine light flashes!?
    By 1fastz71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2010, 09:13 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. service engine soon light =[
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2009, 10:06 AM
  4. Blinking service engine soon light.
    By lutman123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2009, 11:27 PM
  5. Service engine soon light
    By the955iman in forum General Tech Discussion
    Last Post: 02-15-2009, 01:21 PM
