Thread: So, putting engine back together after cam install
Results 1 to 11 of 11
  1. #1 So, putting engine back together after cam install
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    What I'm doing is usind an L26 with my L67 heads. I have engine on an engine stand, and had it upside down to remove the oil pan to install the front cover after installing my cam. My question... I Heard that there is an issue with these oil pumps priming after the oil has run out.? I heard of people packing pump with petroleum jelly to help prime? Is this something I should be doing or what?
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  2. #2 Re: So, putting engine back together after cam install
    Charles City, IA
    Just put some oil in the pump, then when you go to start it prime it a few times by disabling fuel and cranking for 15secs about 5 times.
    SMGPFC Two Nipple General
  3. #3 Re: So, putting engine back together after cam install
    Dec 2008
    PA
    Ten Four thanks
  4. #4 Re: So, putting engine back together after cam install
    Charles City, IA
    not a problem rubber ducky.
  5. #5 Re: So, putting engine back together after cam install
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    This is Big daddy from Cincinnati, over and out good buddy. What parts of Pa you from?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: So, putting engine back together after cam install
    Wichita, KS
    I fill the oil pump up with petroleum jelly before the front cover goes back on. It will break down in the oil easily.
    You can also use white lithium grease too, same thing, but it will screw with you, as it breaks down, it will turn the oil a milky color, and make you think your coolant is leaking into the oil. That's why i stick with petroleum jelly myself.
    Pack the oil pump gears full, and retorque the pump cover correctly, and evenly, and your good to go on that part.
    ~F~
  7. #7 Re: So, putting engine back together after cam install
    Dec 2008
    PA
    I'm about half way between York and Harrisburg in Etters, PA. Not too far from Hagerstown. Should have car done by spring time. Too much other stuff going on right now.
  8. #8 Re: So, putting engine back together after cam install
    GM way is jelly.
    But who trusts GM?
  9. #9 Re: So, putting engine back together after cam install
    Charles City, IA
    I just lubed mine with oil since I was going to prime and start the engine the same day. If it will sit a while the grease would be the best way.
  10. #10 Re: So, putting engine back together after cam install
    Dec 2008
    PA
    I was thinking about just filling it with oil, but I figured that when I turned it over to install the oil pan, it would all run out. I think the petroleum jelly sounds like a good way to go.
  11. #11 Re: So, putting engine back together after cam install
    I end up seeing a lot that were sitting around or oil filter adapters have been off etc.
    Usually I pull the ICM connector and crank away a few times (like previously mentioned) and it works great every time.
  1. Putting Factory Stereo Back In 2000 gp
    By MysticStyl3z in forum Audio, Security & Visual Electronics
    Last Post: 09-01-2010, 03:51 PM
  2. Car wont run after putting SC back in
    By funky4stringed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2010, 10:13 PM
  3. Putting front end back togeather
    By Ineverfollow in forum General Tech Discussion
    Last Post: 12-15-2009, 03:46 AM
  4. HVAC Cluster Back Lights / CB Radio Install
    By POLECAT2007 in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2009, 09:47 AM
  5. engine revs when putting into gear
    By breeze12 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-07-2009, 09:28 AM
