Thread: AjL227's XP, S2 IC, 2.8" CompG build
Results 21 to 40 of 113
Threaded View
  1. #1 AjL227's XP, S2 IC, 2.8" CompG build
    GTP Level Member AjL227's Avatar
    IL
    UPDATE 9/21/11: WHATS NEXT? UPCOMING
    SKIP AHEAD TO THIS THREAD FOR NEW POSTS
    >>>NEW UPCOMING PLANS<<<
    This thread is directed to my 2004 GP GTP CompG and it's modifications.
    I got this car with 7,xxx miles on the odometer, in February of 2007. It was all stock with Enkei 10 spoke alloy wheels.
    To this day, it has 68,xxx miles. This car is daily driven.
    -HPTuners Pro VCM suite
    -DHP
    -Comp Cam's X-P hot camshaft (212,224/.325.335/116LSA)
    -Rollmaster double roller timing set (properly machined)
    -105# valve springs
    -qwik port stock heads (casting #8)
    -ARP head studs
    -Cometic MLS .052" head gaskets
    -ZZP MPS 3.0"
    -ZZP 2.25" aluminum A2W intercooler system w/ silicone hoses & bosch pump (100% resealed/leak free)
    -ZZP billet fuel logs
    -Mototron 80#/hr (800cc) injectors
    -E85 (summer) / 93 octane (winter)
    -Poly upper engine mounts
    -ZZP billet aluminum upper engine supports
    -Poly lower engine mount
    -Poly transaxle mount
    -ZZP stainless headers
    -ZZP 3" 304SS downpipe
    -ZZP 3" 304SS catback exhaust
    -30" 304SS Magnaflow resonator
    -KYB GR-2 gas shocks
    -SSC lowering springs w/ anti-pogo washers
    -GXP brakes
    -Xenon HIDs 10,000k
    -Aeroforce scan gauge
    -AEM vac/boost
    -AEM wideband o2
    -AEM fuel pressure
    Progress:
    In-car tear down
    Engine is out
    Cam install
    Block, heads and timing set
    Valvetrain, front cover and intake
    Money shots
    Engine is in, and buttoned up
    Gas shocks, lowering springs & GXP brakes
    85mm LQ4 MAF & Mototron 80#/hr injectors
    ZZP I/C overhaul...new core, plates resealed, new hoses
    3.0" pulley IDLE VIDEO
    12 second pass, 110+ MPH @ GREAT LAKES DRAGWAY
    NEW UPCOMING PLANS
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  1. Are the compg gtp's faster than the non compg gtp's?
    By GMCARS4LIFE in forum Off Topic Discussion
    Last Post: 03-07-2011, 09:19 PM
  2. Turbo Build "UPDATED 12/22/2010"
    By bbptech in forum Turbo
    Last Post: 12-22-2010, 12:06 PM
  3. 04 CompG from MN here, Hello!
    By chili in forum Introductions/Noob Questions
    Last Post: 06-06-2009, 05:15 AM
  4. My CompG
    By RKELC in forum Visual/Body Modifications
    Last Post: 04-29-2008, 06:57 PM
