Thread: Valve Cover
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: Valve Cover
    Yup, since the heads are different, the bolt pattern for the valve covers are also changed.
  2. #22 Re: Valve Cover
    I thought the bolt patterns were the same... just the added room for the injectors.
  3. #23 Re: Valve Cover
    Pretty sure last time I lined a couple up, besides the injector bosses...the bolts were in different spots too.
  4. #24 Re: Valve Cover
    PCMO
    Thanks guy all this info is great and makes me want to do some mods myself. Don't want to get to carried away as my son will proly get this car in 2 years when he is 16!?!?
  5. #25 Re: Valve Cover
    do him a favour.
    if he likes driving sign him up for some racing lessons.
    That ought to solve your problem...
    PCMO
    Got the Valve cover off cleaned everything off and found, at the top of the cover where it molded around the fuel injectors, the material is thin and brittle. This has got to be why it is leaking again. There are rub marks where the injector sits too.
    gonna have to get it good enough until I can get new covers. local auto parts don't have them.
    Will install the felpros gasket set with RTV and hopefully that will keep it.
    Any body know a good place to get replacements that are not overly expensive?
    Last edited by matt5112; 12-11-2010 at 10:27 PM. Reason: Two posts with slightly different info...
  7. #27 Re: Valve Cover
    dont get new covers unless they are broke. Just get BETTER gaskets.
  8. #28 Re: Valve Cover
    Its not because the covers are thin.... its because the gasket was compressed and no longer making a seal.
    Get new gaskets and new grommets and you'll be okay.
  9. #29 Re: Valve Cover
    New Jersey
    Last time I checked the plastic composite valve covers were A LOT more money then metal ones, including aluminum.
    Just thought I'd throw that into the mix.
  10. #30 Re: Valve Cover
    Denver
    I've seen the same thin condition on my valve covers (near the injectors).
    The leaking condition was fixed by a new gasket/grommet job. There was nothing wrong with the composite gaskets (that was causing the leaking).
    Unless you want a prettier valve cover, the OEM composite ones will be fine (even with the thin wall condition).
  11. #31 Re: Valve Cover
    Newfoundland
    Not sure how many people know this or Replied, But The front valve cover gasket is recalled on all the 3800S/C Motors, Bring it to you local pontiac dealer and they'll fix it for free.
  12. #32 Re: Valve Cover
    Resident ZZP Leg Humper BoostenGTP's Avatar
    Grand Rapids, MI
    Quote Originally Posted by 90oddz View Post
    Has already been addressed. I did my gaskets myself though, screw taking my modded car to a dealership. They would look at it and go "wtf do i do with this!? whats that shinny thing there under that spinning intake system thingy there?"
    2014 Mustang GT Sterling Grey 5.0 Track Package NEW 2000 Grand Prix GTP Red SOLD
    2000 Mustang GT LTR SOLD 2000 Grand Prix GTP Silvermist SOLD
  13. #33 Re: Valve Cover
    Guy, new gaskets are useless without good grommets. Might as well get them all and do them all properly and forget about it for a while.
    Quote Originally Posted by BoostenGTP02 View Post
    LOL.
    they'd just hand you the gasket.
  14. #34 Re: Valve Cover
    Donating Users onetyme77's Avatar
    texas
    so wen i change my gaskets there are grommets i need to buy also or does it all come in one kit??
  15. #35 Re: Valve Cover
    you can get the kit with everything,
    i think for l67's its easier to get everything and for l36 its easier to get them separately.
  16. #36 Re: Valve Cover
    texas
    mine is not s/c so which is that ?
  17. #37 Re: Valve Cover
  18. #38 Re: Valve Cover
    PCMO
    I have replaced the front valve cover with a used one that was in better condition than mine. I used felpros gasket with some silicone. I hand tightened the bolts, so as not to over torque. Still getting oil around the top side of the cover. Thinking how oil gets up, I replaced the PCV valve, changed the oil and cleaned the area around the cover. It still looks like I am getting a bit of oil around the top side still. Any Ideas??
    Alsooo, while attempting to replace the rear cover I was removing the housing that has the heater line for the heater core. the line that goes into the engine block is now seeping anitfreeeze. I did not completely remove this line because I was not prepared at the time for this to come off and did not have the fluid drained. Is there a gasket/ o-ring for this and what exactly would I ask for?
  19. #39 Re: Valve Cover
    Local parts store.
    dorman/ HELP! number 47065
    $4
  20. #40 Re: Valve Cover
    PCMO
    Found out it was not the VC that was leaking it was the lower and upper intake manifolds.
  1. Valve Cover recall
    By blktalon456 in forum General Tech Discussion
    Last Post: 02-26-2010, 01:00 PM
  2. Valve Cover choices
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2009, 08:30 PM
  3. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
  4. Valve Cover Removal
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2008, 07:19 PM
