Thread: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
Results 1 to 20 of 28
  1. #1 Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    Recently had my lim removed and supercharger for a lifter replacement. I noticed my boost gauge at idle would jump from 20hgs to 10hgs every 6 seconds. I plugged my hptuners in and ran a scan. Noticed on the map sensor gauge it would go to 35kpa to 65kpa every 6 seconds following my after market boost gauge. I checked all my vac lines, looked good to my knowledge. I checked the diagram also. Also when on the highway when slowing to get of the exit it stays at 10hgs on the boost gauge and 65kpa at the map sensor on my hp tuner. Car idles and drives fine. Do you guys have any ideas what might be going on. Sorry for the long read. TIA.
    1.9 Rockers- 42.5 injectors- 3.4" mps- Wizaired 104s- 180*- PRJ 10mm wires- SD headers 3" DP- Hp tuner- Dynotech stage 2- 3.29s 1'' chain
  2. #2 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Charles City, IA
    I beat there is a vac leak at your tb spacer.
    SMGPFC Two Nipple General
  3. #3 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    scan idle air counts and see what they say
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    If theres a leak at the spacer, i replaced both gaskets though, should I pull it apart again and use blue gasket sealer on both sides of the gaskets?
  5. #5 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    ok I scanned the idle steps at idle heat off. Goes between 15 to 18 steps if Im reading it right. Then when I turn the heat on it goes to 25 to 28 steps. The boost gauge stays right at 18hgs. But as soon as I turn the heat or air off the boost gauge moves to 10hgs and back to 20hgs every few seconds. Weird... Thanks for the help so far.
  6. #6 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Hagerstown,Md
    Idle air counts should read in the mid 40's at idle. Sounds like you have a vac leak. Are your LFT's maxing at 16.4 aswell at idle and decel?
  7. #7 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
  8. #8 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    I guess i have a vac leak.... But srsly my throttle plate doesnt seal...
  9. #9 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
  10. #10 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    I have the spacer there for my nitrous port. At Idle my lifts are normal. I will scan again right now and look.
  11. #11 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    The throttle plate in a non DBW car should seal....
  12. #12 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Hagerstown,Md
    this is assuming you have a stock cam. Cams can change Air counts
  13. #13 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    I have stock cams.
  14. #14 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Hagerstown,Md
    Yeah Id say you have a vac leak. Id take a spray bottle and spray around with a high concentration of soapy water and see what you find.
  15. #15 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    Ok just scanned again and my LTs are at 13+ at idle and when i rev it goes to 2+ and then back to 11-13LTs Short term fuel is steady at 0.0 to 0.3
  16. #16 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    But if its a vac leak how would soapy water work, wouldnt it just suck the stuff in instead of making bubbles.
  17. #17 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Hagerstown,Md
    yep probably a leak. It works you will see the bubbles get pulled in, and the water around will bubble up as the waters drawn in
  18. #18 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    is the vac leak near the throttle body?
  19. #19 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Hagerstown,Md
    Quote Originally Posted by 02grandprix View Post
    Could be. Could also be at the Blower/Lim. Could be at the EGR tube. Could be vac line itself
  20. #20 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    No luck, maybe i ll grab some carb cleaner or starter fluid later on today and give that a try, or is there a better way to do it?
  1. Exterior Temperture Sensor reading OC
    By SNeitzel in forum General Tech Discussion
    Last Post: 10-01-2010, 11:28 AM
  2. Car shuts off after a few seconds of running
    By Kissner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2010, 10:51 PM
  3. Car kills out after a few seconds
    By Kissner in forum General Tech Discussion
    Last Post: 03-16-2010, 07:32 PM
  4. Car starts but stalls after 2 seconds
    By cartooz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 06:18 AM
  5. Please take 2 seconds and vote for us to get a strip
    By Z28 in forum Off Topic Discussion
    Last Post: 07-27-2009, 06:19 PM
