I already moved the injector when I replaced the o rings so I think that would eliminate the injector.
Well then, I guess it is onto the ICM.
I just noticed that the vacuum line to the evap canister is missing that couldn't cause a misfire could it? And where the heck is the evap canister at anyway, I couldn't find it.
vac leak would make it run lean and could cause a miss.
Something real similar to this happened to my friend just recently, he had a miss on cyl #5 and replaced everything and couldn't figure it out for a long time. It turns out in the end that his fuel trims were bad. We then Put the stock PCM back in an it ran perfect.
what kind of plugs are they,NGK is the way to go if not then delco are ok too,3.8s are picky bltches
So I drove the car halfway across the state for work, then scanned it when I got home, now its putting up the code P0300 random multiple cylinder missfire. So I am more convinced that it is indeed a bad ICM.
Well a little update on this here is a list of things I have replaced/removed trying to figure out wtf is going on.
- Checked 800 times for vacuum leaks
- New Autolite 104's gapped at .055
- New Premium Wires
- Swapped out all the coils twice
- Swapped out the icm twice
- Removed the cat
- Removed Egr
- Swapped injectors around
- Replaced all the orings
- Replaced new Powerbond SFI Harmonic Balancer
- Replaced Crank Position sensor
Still have random multiple misfires.
This screen shot is from the car idling after a 15 min cruise down the highway. I tried to get a scan but when I opened the file it was blank
Replaced Cam Position sensor today and still random multiple missfires........ that leaves only 2 more things that could be wrong the computer is bad or I have multiple chipped pistons.
Went for a cruise down the highway for about 15 min, and my Timing Advance is all over the place while cruising its anywhere from 0* to -29.5* LTFT1 was pretty constant at -8.53975% had a short blip for a few seconds to -7.8125%
So anyone have a spare engine they want to sell.
Ouch..
my buddy has got one down here that he might want to sell
let me know and Ill get a hold of him
