Thread: PCM problems, GT to GTP
Results 1 to 16 of 16
  1. #1 PCM problems, GT to GTP
    Greenville, SC
    The car is finished, all i need now is a PCM.
    I bought one off a GTP and put in it my car and the fuel pump will not prime.
    I put my old PCM (GT) back in, the fuel pump works fine.
    It obviously isnt my fuel pump. Is there a difference in the pins on the PCM?
    This has been tested on 2 different pcms.
    Im so LOST
  2. #2 Re: PCM problems, GT to GTP
    you need a combination of the two PCM's else your car wont run.
    do NOT drive it with the GTP pcm because your tranny tables will be very off.
    unless you swapped transmissions as well.
    What year is your car and what year is the GTP PCM that you have?
  3. #3 Re: PCM problems, GT to GTP
    Greenville, SC
    Car is a 98 and the pcm is a 98 too as far as i know.
  4. #4 Re: PCM problems, GT to GTP
    I've heard you need to start with the GTP bin file and change stuff around...at least that is how it worked on Gafford's car...
  5. #5 Re: PCM problems, GT to GTP
    Greenville, SC
    im getting a friend over in a few hours, im going to try his PCM and if it doesnt work then, i know its a problem with my car.
  6. #6 Re: PCM problems, GT to GTP
    Aren't they fun?
    I love W-Body's.
  7. #7 Re: PCM problems, GT to GTP
    Greenville, SC
    seems like i ended up with a PCM from a pre 98 car. its the huge bulky looking one. the one from the GT is flat looking. will anything post 98 work?
  8. #8 Re: PCM problems, GT to GTP
    Charles City, IA
    Sticking with the same year would be best, but 98-02 should work.
    SMGPFC Two Nipple General
  9. #9 Re: PCM problems, GT to GTP
    Jersey
    sounds like you got a 97 pcm. The pin outs are different.
    97 pcms are 1 year only
    16' wrx sti- stock
  10. #10 Re: PCM problems, GT to GTP
    Greenville, SC
    Quote Originally Posted by 99prixgt View Post
    Yep i ran the Service # and it is a 97 gotta find a 98.........
  11. #11 Re: PCM problems, GT to GTP
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    what trans did you use? Id just use the GT pcm and load in gtp bins
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  12. #12 Re: PCM problems, GT to GTP
    Easier to do that on an SSM90 kit...there are problems run into using a GT PCM, such as not having parameters in the PCM for boost...or so I've heard...but I don't know...I don't tune.
  13. #13 Re: PCM problems, GT to GTP
    Largo, Florida, United States
    Quote Originally Posted by saleenprix View Post
    I have a 98 PCM for sale! works fine was the stock PCM i was using in my car before i ordered a Tuned one for my 3.4 setup
  14. #14 Re: PCM problems, GT to GTP
    Hagerstown,Md
    Nah you can load it in for a l67 map. No issues I can see. might have to unhook the BBV and just let it operate with vacuum. Thats about it. I run a l32 map in mine FWIW
  15. #15 Re: PCM problems, GT to GTP
    We had to do that on the BBV with Gafford's car...
  16. #16 Re: PCM problems, GT to GTP
    thats only because you didnt run the wiring for it...
  1. So many problems. . .
    By SDGTP99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2010, 02:09 PM
  2. A few problems with my GTP
    By Girevik in forum General Tech Discussion
    Last Post: 02-10-2010, 02:08 PM
  3. Problems getting hub off
    By chevy man in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2010, 11:26 PM
  4. A/C problems
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 11:04 PM
  5. problems problems problems!
    By NomeCrusher in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-14-2009, 03:26 PM
