Thread: NIC cam questions
Results 1 to 20 of 22
  1. #1 NIC cam questions
    Jersey
    I've been heavily debating a nic cam lately. What would i need? i see zzp and other members are using a double roller, do i really need a double roller for this cam? Is it because of the loopy idle? What kind of powerband would i get with this cam, i would guess low end to mid range? what is everyone reving to? 6-6,500k? I already have 105# crow springs would these be ok and not too aggressive?
    I have all gaskets and everything along with a brand spankin new xp cam sitting in my basement since last march, im procrastinating install since im afraid i won't be happy with the end results.
    I really, really would like to see mid to low 12's non- intercooled with as small of a pulley i can
    the car is a gt with a gen5 top swap, mods listed in sig.
    16' wrx sti- stock
  2. #2 Re: NIC cam questions
    NIC is the you must wideband tune and watch it cam.
    but its epicly quick.
  3. #3 Re: NIC cam questions
    Charles City, IA
    I would stick with the xp since you allready have it. You should be able to hit 12's with that.
    SMGPFC Two Nipple General
  4. #4 Re: NIC cam questions
    XP also works great with N2O
  5. #5 Re: NIC cam questions
    XP is also a great cam and goes GREAT with bigger injectors and a full-size IC.
  6. #6 Re: NIC cam questions
    Charles City, IA
    It also does great with new tires.
  7. #7 Re: NIC cam questions
    Even going from N/A to S/C requires better tires IMO.
  8. #8 Re: NIC cam questions
    Any power increase needs some sort of way to get it to the pavement...suspension, mounts, tires, trans...
  9. #9 Re: NIC cam questions
    Got the first two downish...
  10. #10 Re: NIC cam questions
    Jersey
    so its either xp cam and i/c or nic cam
    seems like every xp camed car is stuck in the 13's which is something that i would dread. I'm begging for 12's without the use of an i/c. Tuning all the time isn't an issue since i barely drive the car anyway. What kind of powerband is it tho?
    16' wrx sti- stock
  11. #11 Re: NIC cam questions
    tell me why you want to run a NIC and maybe ill tell you why you shouldnt.
  12. #12 Re: NIC cam questions
    a NIC cam + E85 would be quite quick.
    As would an XP with E85 though.
  13. #13 Re: NIC cam questions
    Largo, Florida, United States
    This
    XP with your mods should hit 12's unless you need a new driver mod.
  14. #14 Re: NIC cam questions
    Jersey
    mainly to have a little more different setup, hit 12 without i/c, run real small pulley, and the nasty idle.
    YouTube - Grand Prix GTP w/ NIC cam and other mods
    16' wrx sti- stock
  15. #15 Re: NIC cam questions
  16. #16 Re: NIC cam questions
    You want a NIC if you always like tuning and wondering if your gonna be buying a short block next weekend.
  17. #17 Re: NIC cam questions
    Charles City, IA
    You did that with an xp tho...................
  18. #18 Re: NIC cam questions
    Donating Users kfish's Avatar
    Ohio
    hey me too!
  19. #19 Re: NIC cam questions
    You did that with a Thrasher too...so your argument is MOOT LOL
  20. #20 Re: NIC cam questions
    How about we abandon cams and follow that guy running 13.67?
  1. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  2. HV3 Questions
    By SuperSport in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-02-2009, 05:38 PM
  3. A Few questions
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 12:23 AM
  4. A few questions
    By Shaunk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2009, 09:36 PM
  5. pcm questions - need help
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2009, 05:07 PM
