Thread: Disable Supercharger
Results 1 to 20 of 22
  1. #1 Disable Supercharger
    May 2008
    Olmsted Falls, OH
    Is there a way to disconnect the Supercharger to save gas maybe by taking a belt off?
    Thanks
  2. #2 Re: Disable Supercharger
    Warren, MI
    I'm sure someone will correct me if I'm wrong, but yes you should be able to do that w/o any problems. I thought I have read somewhere before about people doing that, besides the belt for the S/C only runs the S/C right? The rest of the accessories should run off the other belt.
    04 White GP Comp G
    Mods: Intake, 180 T-stat, AL 104's, HID's, Tint, Debadged, Alt. Re-wire (so far...)
    Future plans: PCM, 3.5 MPS, and possibly headers.
  3. #3 Re: Disable Supercharger
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Taking the belt off will "disable" the supercharger...but you will get better gas mileage by just staying out of the throttle with the supercharger connected.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  4. #4 Re: Disable Supercharger
    Wichita, KS
    X2 with above.
    If you have a MPS, run a larger pulley, and keep put of the throttle.
    Taking the belt off will make the car so sloooooooooooow you will be giving it more throttle to get it up and going, and for sure the MPG could drop for sure keeping that up. And regardless, when you don't have your supercharger, you will need it or want it sometimes. I feel like that every day driving the work truck around. Big bummer not having boost behind my foot.
    ~F~
  5. #5 Re: Disable Supercharger
    May 2008
    Olmsted Falls, OH
    Thanks for the quick replies.
  6. #6 Re: Disable Supercharger
    Apr 2008
    84, PA
    Just by taking off the belt for the SC my DIC was giving me 2-3 mpg more. I haven't tested this by hand and paper but there was a few times that I almost got hit pulling out and being able to hammer it to make tight gaps in traffic. I'm averaging about 21-23 mpg in town with 107,500 miles on th engine. Only things I've done to it is replaced a few idler pulleys and new autolite plugs.
  7. #7 Re: Disable Supercharger
    TDCRacing
    Guest
    boost bypass mod reversed...boost still but later in the throttle
  8. #8 Re: Disable Supercharger
    Wichita, KS
    LOL the D.I.C. is the most worthless gimmick on our cars. Its a reference or a guideline as to what is really going on. Do the math, the numbers never lie on MPG.
    ~F~
  9. #9 Re: Disable Supercharger
    May 2008
    Goderich Ont. Canada
    It does make a difference, but only in the city not on the highway, I just had to put a coupler in my supercharger. I didn't find it that much slower than when I had my 97 SE with the 3.8L . Besides the GTP's are better on fuel than the SE's or the GT's on the hwy.
  10. #10 Re: Disable Supercharger
    Saraland Alabama
    Quote Originally Posted by Darkcelle View Post
    you get bad mileage then, I am getting 23 with mine running the s/c and have a cam (and 150k on the engine)
  11. #11 Re: Disable Supercharger
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    I think the S/C wont even kick in unless u give it about 50% throttle or more... (I dont know if thats the exact % btw)
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  12. #12 Re: Disable Supercharger
    TDCRacing
    Guest
    Yeah don't go b the dic it's not accurate.
  13. #13 Re: Disable Supercharger
    Bartlett, IL
    Quote Originally Posted by TDCRacing View Post
    How To: E-Brake Pwn
  14. #14 Re: Disable Supercharger
    May 2008
    Quote Originally Posted by archemedes View Post
    Maybe in your case you get bad mileage, I was refering to my stock GTP gets better mileage in the city without the supercharger belt but only 1-2 mpg's.
  15. #15 Re: Disable Supercharger
    Saraland Alabama
    Quote Originally Posted by louie View Post
    your getting the same as I am and mines not stock is my point. Disabling the sc will cause an air restriction so it shouldn't help (you have to get air past the rotors that are no longer spinning)
  16. #16 Re: Disable Supercharger
    GT Level Member DesQ27's Avatar
    May 2008
    Kennewick
    more power equals less throttle..and your extra power is coming from air which is free...yes it takes engine power to move the supercharger, but you get more power out of it which in turn means less gas needed for everyday driving. Also, the supercharger doesn't inject the boost unless your at a certain throttle point, or under load.(someone can explain it better) Which means sometimes your not using it anyways. I would just leave it on, and research other options, like fuel filter change, light throttle, open exhaust a bit, stuff like that will help. I'm sure others can pitch in ideas that have worked for them... BTW I get 21mpg when I'm heavy on the throttle around town, and over 25 if I drive like my mom. (almost 40 on the highway) So I'd check your throttle, or look over regular maintainance.
    "True measure of a man's strength is his self control in time of great stress" - ME
    2002 GTP: U-Bend and Resonator Delete; Mufflers Modded; K&N Short Ram Air; WS6 Ram Air Hood
  17. #17 Re: Disable Supercharger
    May 2008
    Kennewick
    Also I have notice a lot of dislike for the GP's DIC...why is that???
  18. #18 Re: Disable Supercharger
    TDCRacing
    Guest
    I love them...i didnt mean to come across like that...but as far as the mpg estimated by the dic that can sometimes be wrong because the dic assumes that the LTFT+STFT are at zero...wich is not always the case.
  19. #19 Re: Disable Supercharger
    May 2008
    I am getting 31 mpg's on the highway and with the belt on in the city it was 27.2 mpg's and without the belt on it went to 29.4 mpg's, you stated you were getting 23 mpg's. I don't know how that's the same. I was only stating my experience.
  20. #20 Re: Disable Supercharger
    TDCRacing
    Guest
    Hey I look at it like this everyone. I bought my damn car because it was fast as it was stock. I had no intention of getting Awesome gas miliage and if i did i would not have bought a sepercharged car. or any v6 for that matter. Sure prices of gas has gone up. But it's nothing i didnt expect. and i really dont think it should have been a suprise to anyone.I didnt buy a supercharged car and spend over 7000 on mods to disable the freakin supercharger. If i can improve on gas milage by using what i have without sacraficing power then sure i will, thats why i have a tuner. With my mods in my sig i am getting the same mpg if not better than a totally stock gtp that has done every maintence procedure available to try to improve the mpg. Gas- your going to need it regardless.Your going to buy it regardless. Your going to use it regardless. No matter the price. Thats why i dont even bother complaining. just my 2 cents.
  1. How to disable my day time running lights ??
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2010, 08:54 PM
  2. disable lockup 1999 regal gs
    By smokingjoe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-25-2010, 10:35 AM
  3. How to remove the supercharger ?
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 04:20 PM
  4. supercharger gen q's
    By TDCRacing in forum General Tech Discussion
    Last Post: 05-06-2008, 10:13 PM
