Thread: Exhaust flange gasket direction???
Results 1 to 20 of 23
  1. #1 Exhaust flange gasket direction???
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    Which way does the flange gasket go on? There is an "indented" circle and I was just curious if that is supposed to face the cat or the resonator. Here are the pics:
    As you can see here is the "bump out" side with the part number stamp on it.
    and here is the "bump in" side without the part number stamp.
    Thanks!
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  2. #2 Re: Exhaust flange gasket direction???
    Panama City Beach, FL
    Technically, it shouldn't matter, as the theory behind those gaskets is that they are compressible (footprint) gaskets, but per GM Service docs, the "bump out" side is to go to the manifold, as it's the more rigid surface.
  3. #3 Re: Exhaust flange gasket direction???
    Tyler, TX
    Quote Originally Posted by 02 WS6 TA View Post
    So "the "bump out" side is to go to the manifold" .... towards the cat?... since that's the direction of the manifold?
    this is going between the cat and the resonator on the down pipe.
    ....gotta make it dummy proof for the dummy installing it
  4. #4 Re: Exhaust flange gasket direction???
    Tyler, TX
    Any good reason that the gasket would blow out on the bottom half?
  5. #5 Re: Exhaust flange gasket direction???
    My best guess is the flange being warped (see my pm reply) but yes, toward the thicker of the flanges. Dammit, put an LS in that thing so I can reply without thinking. LOL.
  6. #6 Re: Exhaust flange gasket direction???
    Tyler, TX
    ........there's a GTO for sale when I dropped in to get the gasket.... ughh, I'm too upside down to get it though
    guess I'll bring out the BFH tomorrow while I got it on the lift.
  7. #7 Re: Exhaust flange gasket direction???
    Tyler, TX
    hmm, not seeing a PM..
  8. #8 Re: Exhaust flange gasket direction???
    Whiskey, tango, Fox... Anyway, I just suggested trying to re-warp the flange in the opposite direction so as to preload it to combat the tendancy to horseshoe bend it when tightening it...
    GTO...Dooo Ettt... :lol: I am fighting the urge to get Mel a G8 GT...
  9. #9 Re: Exhaust flange gasket direction???
    Tyler, TX
  10. #10 Re: Exhaust flange gasket direction???
    As I... The payment book un-taunts me however. :lol:
  11. #11 Re: Exhaust flange gasket direction???
    Tyler, TX
    If I would actually get to drive it, I would talk the wife into getting it.... but I just can't justify buying something and then letting it bake in the sun for a year.... maybe when I get back.
    ....though, I'll test drive anything for fun
  12. #12 Re: Exhaust flange gasket direction???
    Haha, hear ya there. I'll eventually score one for her. I just like to lie to myself about my intentions.
  13. #13 Re: Exhaust flange gasket direction???
    Quote Originally Posted by 03GTPLE View Post
    I'm just gonna use the BFH and wack the crap out of the flanges. Do you suppose there is such a thing as too far back?
    Uh, Yeah, I would say there is such a thing... Try the LBFH. Or, try a 1/4" extension between the top and bottom, and gently tighten to achieve the desired warp.
  14. #14 Re: Exhaust flange gasket direction???
    Tyler, TX
  15. #15 Re: Exhaust flange gasket direction???
    Tyler, TX
    ehhh... what?
  16. #16 Re: Exhaust flange gasket direction???
    Tyler, TX
    wanna swing up this way tomorrow?
  17. #17 Re: Exhaust flange gasket direction???
    "Swing up" that way? LOL Just call me when you get ready to work on it, I'll explain. hahah
  18. #18 Re: Exhaust flange gasket direction???
    Tyler, TX
    yeah... guess I forgot to add the sarcastic smiley on that one...
    you free around lunch? (11:30 ish)
  19. #19 Re: Exhaust flange gasket direction???
    Tyler, TX
    although, I really want to know what you're tightening with the 1/4" extension... and top and bottom of what?
  20. #20 Re: Exhaust flange gasket direction???
    Tyler, TX
    oh, do you mean put the extension through the bolt hole and pull on it?
  1. Water vapor in exhaust after LIM gasket repair
    By Obrigado in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-26-2010, 08:12 AM
  2. gtp modding direction
    By eddyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 05:24 AM
  3. Exhaust gasket #?
    By Black18Ice in forum General Tech Discussion
    Last Post: 10-07-2009, 09:43 PM
  4. Removing collector flange bolts without breaking anything.
    By BackInBlack in forum General Tech Discussion
    Last Post: 07-25-2008, 12:31 AM
  5. Movement in the other direction!
    By GPGT08 in forum Tires & Wheels
    Last Post: 07-01-2008, 05:06 PM
