Thread: Rotating assembly repair without removing engine?
Results 1 to 18 of 18
  1. #1 Rotating assembly repair without removing engine?
    Apr 2009
    Fort Worth TX
    I just purchased a 2002 GTP coupe with 84K. The car is in mint condition except for the motor. At about 4000rpm the motor has a knock somewhere in the rotating assembly. It also appears to have a problem with the LIM gaskets; water in the oil. I plan on replacing the LIM and supercharger gaskets soon. Scanned the PCM - no DTCs
    Question:
    In the case that the knock is not from a missfire, what kind of rotating assembly repairs can be performed without removing the engine? The knock sounds like a rod bearing or piston slap.
    Any comments are greatly appreciated.
    ...hope I posted this in the correct section
  2. #2 Re: Rotating assembly repair without removing engine?
    you can do anything up until replacing bottom end components without taking out the motor.
  3. #3 Re: Rotating assembly repair without removing engine?
    Honestly...if your up to the task...I bet you can rebuild the entire motor with the block still in the car if you want. You can drop the cradle and yank everything out the bottom and pull everything from the heads up from the top.
  4. #4 Re: Rotating assembly repair without removing engine?
  5. #5 Re: Rotating assembly repair without removing engine?
    Charles City, IA
    Yeah pulling the motor takes like an hour.
    SMGPFC Two Nipple General
  6. #6 Re: Rotating assembly repair without removing engine?
    It's tough to sneak the flywheel out w/o unbolting the trans from engine. If you want to fix any part of the rotating assembly and don't take it to a machine shop (in which case a used motor is usually cheaper) then you will have the 200 mile motor. In about 200 miles it'll likely fail again.
  7. #7 Re: Rotating assembly repair without removing engine?
    Donating Users kfish's Avatar
    Ohio
    werd.
  8. #8 Re: Rotating assembly repair without removing engine?
    Quote Originally Posted by kfish View Post
    werd.
    werd werd
    or werdx2
    or werd^2...well...
    that's be like werd werd...
    ya.
  9. #9 Re: Rotating assembly repair without removing engine?
    Apr 2009
    Fort Worth TX
    All
    Thanks for the comments.
    The reason for the question is that all my tools are up in Pennsylvania and I now live down here in Texas. My garage is all jammed up with crap anyway...didn't want to leave a motor on a stand in my driveway. Our HOA would have a seizure!
    I'll start with a compression test. If that's good I'll probably drop the pan and unbolt the caps to see if any bearings are toast. If any journals are bad the motor will be removed.
    ...or maybe I can fix the cranksaft with my Dremel tool...just kidding.
    Any other suggestions for troubleshooting?
    Thanks in advance,
    Love this forum!
  10. #10 Re: Rotating assembly repair without removing engine?
    Charles City, IA
    buy a used short block and drop it in.
  11. #11 Re: Rotating assembly repair without removing engine?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    water in the oil with a knock, Sounds like a bearings on the outs. X2 on what 01GTP said, drop in a l36,32,26,or 67 block in there
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  12. #12 Re: Rotating assembly repair without removing engine?
    Or a L754578738435.
    Those are the fast ones.
  13. #13 Re: Rotating assembly repair without removing engine?
    SE Level Member Justin48's Avatar
    Groton, CT
    i know it is un orthadox but could do bearing swap and see if it will clear up the knock... unbolt the oil pan and start with the rod bearings and swap them out one at a time then move to the main bearings you get a hefty cotter pin and cut it down so it goes inside the oil passage in the crank but will catch the bearing but not the block and you spin the crank and remove the bearing just make shure the bearing tab is on the oppisit side of the cotter pin.. process is the same for install just reverse...
    zzp mps 3.2-3.4", prj intercooler core, bosh pump, zzp stage 3 front mount, xp cam, 130# springs,double roller chain, 42.5# injectors, sd headers, 4" fwi, modified prj tune(inprogress) performance shift add, aem wide band, aeroforce.
  14. #14 Re: Rotating assembly repair without removing engine?
    Nov 2010
    Atlanta Ga
    I isolated mine by raising the rpm untill I heard the knock and then used a test light connected to ground to short each wire at the coil untill the noise quit. I used a small piece of vacum hose between the wire and coil tower so as not to damage the wires. This may help you isolate which cylinder. Most of the time I find its the rod bearing and fyi do not reuse the bolts.
  15. #15 Re: Rotating assembly repair without removing engine?
    Apr 2009
    Fort Worth TX
    Sorry for replying to an old post but I just wanted to give an update and ask a couple questions.
    I unbolted the down-pipe, removed the upper mounts, jacked the engine up, removed the lower mount bracket and dropped the oil pan. The mount bolts are hellacious and it was hell getting the oil pan off this car due to the interfering pickup tube. I used a 15mm pivoting ratchet wrench to remove the mount bolts.
    Anyway, I removed the rod caps and someone has been in this engine - big time. Three rod journals are trashed and it has mixed bearings; std, 0.010 etc. I made the decision to rebuild the short block.
    Question: What should I replace on the transmission while I have this thing apart?
    Question: I would like to eliminate the balance shaft. Should I just mig weld the rear oil galley closed or is there a better/safer way? I was thinking milling a rod down to fit the hole and just spot welding it in.
    Thanks in advance for any replies.
  16. #16 Re: Rotating assembly repair without removing engine?
    To keep the pickup tube from interfering, simply remove the oil level sensor before pulling the pan.
    On the trans. Pick up a set of channel plate gaskets. Then go in and replace the 4th hub clutch shaft. Frequently you can pick them up off Ebay for $45ish. Pull the side pan, oil pump, then take the valve body and channel plate together. That way you don't deal with the checkballs or two more gaskets. Zip up the 4th clutches and slide in the new shaft. Reassemble and enjoy knowing you won't lose 4th due to sheared splines.
  17. #17 Re: Rotating assembly repair without removing engine?
    Apr 2009
    Fort Worth TX
    "On the trans. Pick up a set of channel plate gaskets. Then go in and replace the 4th hub clutch shaft. Frequently you can pick them up off Ebay for $45ish. Pull the side pan, oil pump, then take the valve body and channel plate together. That way you don't deal with the checkballs or two more gaskets. Zip up the 4th clutches and slide in the new shaft. Reassemble and enjoy knowing you won't lose 4th due to sheared splines."
    Thanks you Billboost37
    Great info.
    I've rebuilt the valve body on the 4L65E's but going any further than that may not be within my realm of expertise. Especially since I'm unfamilliar with the 4T65E. I guess I'll know better when I get in there.
    Any experience with removing the balance shaft on the 3800?
    Thanks
  18. #18 Re: Rotating assembly repair without removing engine?
    Sure..with the timing set off the motor and the LIM off, stick something in the valley under the shaft so it can't turn. Zip off the bolt/gear with an impact. Leave the shaft in place unless you are rebuilding from scratch because drilling and plugging isn't good in a motor that isn't heading into a tank for cleaning afterwards.
  1. Removing Engine and Transmission together
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-03-2016, 09:32 AM
  2. 04+ removing headlight lens from assembly
    By Piggy in forum Visual/Body Modifications
    Last Post: 07-27-2010, 04:10 AM
  3. Removing Engine and Tranny Together for Dummies Like Me (Write Up)
    By JoeMama in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2009, 06:24 AM
