Thread: Camshaft Sprocket Bolt
Results 1 to 8 of 8
  1. #1 Camshaft Sprocket Bolt
    SE Level Member Andre's Avatar
    Port Coquitlam
    Does anyone know if the camshaft sprocket bolt on a 3.8L Supercharged engine is right hand or left hand thread????
  2. #2 Re: Camshaft Sprocket Bolt
    its a normal thread...right hand? lefty loosey righty tighty.
  3. #3 Re: Camshaft Sprocket Bolt
    It reversed, backwards. So normal And loctite that bish...I like loctiting...EVERYTHING
  4. #4 Re: Camshaft Sprocket Bolt
    Port Coquitlam
    Ok, Thanks!!! Just wanted to make sure.. It's sooo tight, I wanted to make sure I'm not over tightening in the wrong direction!!
    Thanks!!!
  5. #5 Re: Camshaft Sprocket Bolt
    Well...that isn't really a bad thing...I wouldn't want my cam walking like a crank in a 4G63T
  6. #6 Re: Camshaft Sprocket Bolt
    Charles City, IA
    Yeah they are tight, I bent a nice twain wrench into a circle trying to break it loose. Then I got a socket from work and breaker bar.
    SMGPFC Two Nipple General
  7. #7 Re: Camshaft Sprocket Bolt
    Portland Oregon
    It is torque to yield so it will be very tight coming off. I used an impact gun on mine and it spun right out.
  8. #8 Re: Camshaft Sprocket Bolt
    Portland Oregon
    Wow, someone edited this thread. Thankyou for ending it with the correct response
  1. 4T60/E/4T65E Sprocket Ratio Swap !!! [*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 04-08-2015, 10:14 AM
  2. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  3. Camshaft Sprocket Bolt Size?
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2010, 11:18 AM
  4. Camshaft?
    By paratroopermatt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2009, 08:16 PM
  5. Drive Sprocket Support Bearing
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2008, 05:50 PM
