Thread: Intercooling Options
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 70
  1. #1 Intercooling Options
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I have a 2001 Grand Prix GT with the SS M90 kit. I would like to intercool it down the road, but the only one that ZZP says will fit is the SS intercooler, which everyone says to stay away from. Do I have any other options?
  2. #2 Re: Intercooling Options
    Can you not upgrade to Fuel Logs from the factory rails and then just use the SSIC KIT...but a different core, like the stage 2?
  3. #3 Re: Intercooling Options
    Hmmm. I'm not sure. Will it be too thick though? I should ask ZZP.
  4. #4 Re: Intercooling Options
    Vancouver, WA
    IRC fab has a really nice bar and plate style IC I am planning on getting. It is between the size of ZZP's SSIC and stage 2.
  5. #5 Re: Intercooling Options
    Quote Originally Posted by footballplaya3k View Post
    link us, please. no one has ever heard of this company.
  6. #6 Re: Intercooling Options
    If its better than the PRJ core then you're god.
  7. #7 Re: Intercooling Options
    Pennsylvania
  8. #8 Re: Intercooling Options
    Here is what ZZP said about using a bigger core:
    "Clearance issues. The Wbodystore style core clears room for the injectors but you’d still have a few other issues to contend with. It’s been done but it’s not easy."
  9. #9 Re: Intercooling Options
    Quote Originally Posted by SlowNA06 View Post
    smartass.
    looks like they make anything you want, but i dont see anything on there specifically for our cars. id just stick with ZZP for an intercooler, to be honest.
  10. #10 Re: Intercooling Options
    smartass.
    The SSIC? Will it even do anything?
  11. #11 Re: Intercooling Options
    Vancouver, WA
    Idk if these links will work or not but here ya go.
    GTPWORLD.NET • View topic - irc intercooler
    GTPWORLD.NET • View topic - Pics of the I/C and parts they make........
    He already has a GEN 3 and GEN V IC for our cars, just email him or look at my links.
    I'm not sure how the size compares with PRJ but its the same design, bar and plate, which is a much better design for thermal transfer than ZZP's design, but I know most of you already knew that. The main difference from the IRC IC and PRJ's is that PRJ's IC alone costs almost as much as the whole IC setup (IC, FMHE, hose, pump, etc) from IRC.
  12. #12 Re: Intercooling Options
    I'd need more info on the pump and why in the world its a non pressurized system before i'd bite but its nice to know someone else is doing it the right way.
    Still have to work out the PCV system but thats easy.
  13. #13 Re: Intercooling Options
    wow, nice. i didnt expect them to have one designed already.
  14. #14 Re: Intercooling Options
    Topeka, KS
    Not bad. It's always nice to have options.
  15. #15 Re: Intercooling Options
    The whole "i can put my hand on the S/C after 20 WOT runs" sounds too good to be true.
  16. #16 Re: Intercooling Options
    ^^X2.
  17. #17 Re: Intercooling Options
    My fender supports brackets are too hot to rest my hands on after 30 minutes of hard driving.
    Let alone the blower... That thing will melt your face off.
  18. #18 Re: Intercooling Options
    GT Level Member ls1camino's Avatar
    Laurel, MD
    Why doesn't the ZZP Intercooler fit? What is this issue I keep hearing about injectors? I thought the only problem with the intercoolers is that the fuel rails need to be modified to let the blower be pushed up the 2.5".
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  19. #19 Re: Intercooling Options
    Quote Originally Posted by ls1camino View Post
    I have the ZZP fuel logs. That's why I'm confused why a 2.5" intercooler won't fit. ZZP claims there are clearance issues. I have no idea what that means. I wonder if the machined lower intake is higher than a stock one? In that case, it may not clear the hood. You apparently need injector spacers with the intercooler as well (SSIC).
  20. #20 Re: Intercooling Options
    Vancouver, WA
    I'm def not a pro on IC's or anything for that matter but I'm gonna give it a shot. I know william stewart and the guy with a built intrigue are both running an IRC IC setup and they say they are very happy with them.
  1. TB and MAF Options ?
    By Lawngoose in forum General Tech Discussion
    Last Post: 08-23-2010, 07:59 PM
  2. Intercooling or Meth/Water Injection
    By Ttypel67 in forum General Tech Discussion
    Last Post: 06-21-2010, 01:07 AM
  3. What are our options?
    By gdbyrd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2009, 12:17 AM
  4. Intercooling
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2008, 10:56 PM
  5. PCV and Intercooling
    By TooMch in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 11:21 AM
