Thread: Porting heads
Results 1 to 16 of 16
  1. #1 Porting heads
    Feb 2010
    Flint Michigan
    Is it worth the hassel and time to port and polish stock heads, and supercharger?
    I'm only runnin a 3.4, will I be able to drop pulleys, will I notice a difference?
    Also I have almost 190,000 miles, how much power should I try to make, what can this old block handle?
    I have heard to much power you can blow your rings on high mileage motors, is this true?
  2. #2 Re: Porting heads
    Apr 2009
    stockton ca
    any mods in any engine adds stress that being said I wouldt waste the time on a tired engine
  3. #3 Re: Porting heads
    Feb 2010
    Flint Michigan
    So don't do any more than I have?
  4. #4 Re: Porting heads
    There motors run forever. I'd replace all the gaskets while your in there anyways...example...pull the motor.
    Oil pan, front/rear cover gaskets, new oil pump, oil volume kit from a '04+ car, new timing chain/timing chain dampner, Felpro Head Gaskets, GM Aluminum Lower Intake gaskets, new coolant elbow, SC gasket/O-Rings, TB gasket...well...you get the picture. As for porting heads...I can get you a damn good deal...all you have to do is pay me his cost and cover your shipping...PM for more details if you want to.
  5. #5 Re: Porting heads
    how do these oil pumps even fail? its just a gear.
  6. #6 Re: Porting heads
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    Umm.. what is this "oil volume kit" for 04+? never heard of it :/.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  7. #7 Re: Porting heads
    the oil pressure relief valve.
    Basically its a new valve and spring. Goes in just behind the oil filter adapter.
    Change it out for the 04+ spring and valve and boom, more oil pressure.
  8. #8 Re: Porting heads
    Feb 2010
    Flint Michigan
    do you have part number or link for the 04+ oil volume kit?
    if your talking about this http://www.autozone.com/autozone/par...questid=926562
    autozone says its the same part for a 1998 gtp and for a 2004 gtp, so what am i missing?
  9. #9 Re: Porting heads
  10. #10 Re: Porting heads
    GM sells it for $4. Don't buy it from ZZP. Oil pumps can fail from not being lubricated, foreign objects in the gears, etc...just common sense things really...the big one is heat. I think there is a picture of mine on my FB...it was the factory pump that had 89K on it...and it was ground to sh1t.
  11. #11 Re: Porting heads
    Thats the oil pump.
    This is what i'm talking about:
    ZZ Performance
  12. #12 Re: Porting heads
    Feb 2010
    Flint Michigan
    that's different from whY I was looking at.
    What I was looking at was round.
    Bluegtp91 do you have a link? Want to buy the right one.
  13. #13 Re: Porting heads
    Thats the oil pump.
    ZZ Performance
    Right...and that is the same thing as going to your GM dealer and buying a '04+ spring and accumulator kit...FOR FOUR DOLLARS.
  14. #14 Re: Porting heads
    Feb 2010
    Flint Michigan
    so you use the stock oil pump for 1997-02 but you need a spring and accumulator for a 04+, and thats it?
  15. #15 Re: Porting heads
    Pretttttttty much jeeves.
  16. #16 Re: Porting heads
    Feb 2010
    Flint Michigan
    sweet!!!!!
    going to the dealer ship tomorrow and getting it.
  1. Porting Heads. Suggestions Welcome
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 05:56 PM
  2. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
  3. TB Porting ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 06-01-2009, 12:10 AM
  4. porting heads
    By blowfishRus6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2009, 08:57 PM
  5. porting
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2008, 05:29 PM
