Thread: Speed Daddy Headers
Results 1 to 15 of 15
  1. #1 Speed Daddy Headers
    Donating Users lflylow's Avatar
    Yakima, WA
    I have them sitting on my floor right now, I have a grocery list of things I need to get to install them is this correct?
    different exhaust clamps
    RTV sealant
    Possibly a different flex pipe is this really necessary?
    is that all people have been doing to keep them from leaking?
    I have searched and read seems to be it, just looking to verify and be sure.
    2000 GTP, retro's, Debadged, 15% Tint, SD headers, TB HAI, EGR delete,
    Tuned By Reptile, WBS Perf. LCA's, GMPP rear sway bar Dorman front, Tinted tails.
  2. #2 Re: Speed Daddy Headers
    yep get 4 band clamps from napa or where-ever and some rtv to sell them up nice and good. That flex pipe is fine.
  3. #3 Re: Speed Daddy Headers
    Windsor (ON) Canada
    youll need 4 clamps.. 2 3" and 2 2.25". RTV in all joints, o2 sensor extension for pre converter sensor. There is a write up on here which has everything step by step.
    and dont use the gaskets that came with them, they're garbage, re-use the original metal ones.
  4. #4 Re: Speed Daddy Headers
    Jul 2010
    Minnesota
    Downpipe is not an issue unless you drive like an asshat, flex is fine, and I got mine to seal perfect with no rtv. Just bought high torque band clamps and hit them with an impact
  5. #5 Re: Speed Daddy Headers
    RTV everything exhaust wise...it never hurts...why waste time taking it apart again if you have a leak?
  6. #6 Re: Speed Daddy Headers
    Donating Users
    Indiana
    Just installed mine, everything has went really smooth, taking my time. The back header was a pain in the ass to get into the car. Save yourself some trouble and while you have everything out beat a spot in the car for the o2 sensor. Right now mines hitting in reverse. I think rtv saved my life....
  7. #7 Re: Speed Daddy Headers
    Florida
    Yeah, you'll have a hell of a time getting the pre-cat O2 sensor in without taking a hammer to the tunnel.
    Get band clamps, a tube of High Temp RTV, and some WD-40, and you're set.
    As said, reuse your original exhaust manifold gaskets, torque everything down, and you're good to go.
  8. #8 Re: Speed Daddy Headers
    BUy a NGK/NTK o2 sensor...they are a ton smaller than the Denso/ACDelco ones...so they'll fit better without having to beat up the firewall.
  9. #9 Re: Speed Daddy Headers
    Yakima, WA
    has anyone used o2sensors.net to buy new o2 sensors? neither Napa or Autozone carry the NGK 02 sensor.
  10. #10 Re: Speed Daddy Headers
    MA
    sorry post is off topic but i have to say im impressed. no one bashed or busted or flamed or nothing.
    A++ everybody, good job
    (especially blue)
    SMGPFC Member #9
  11. #11 Re: Speed Daddy Headers
    Still wouldnt fit on my car.
    I got lazy and had a bung welded into the crossover.
  12. #12 Re: Speed Daddy Headers
    Florida
    Yeah, mine was really damn close, cause im using shorter dog-bones, so the rear header is pulled up higher...Plus it feels damn good hitting the **** outa a car that has caused so much suffering, lol.
  13. #13 Re: Speed Daddy Headers
    Yakima, WA
    ehh I don't care about beating on the car so that's what I'll probably do.
  14. #14 Re: Speed Daddy Headers
    Really? Because Korey said it fit?
  15. #15 Re: Speed Daddy Headers
    yeah, and "massaging" my firewall didn't seem possible. Its rather thick.
    Just got lazy and did the crossover... $50 to prevent shorting out O2 sensors is worth it.
  1. Speed Daddy Headers
    By ctrout in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2011, 10:37 PM
  2. Speed daddy headers fitment
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2010, 01:47 PM
  3. Speed daddy headers installed.
    By EricGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 03:45 PM
  4. Speed Daddy Headers
    By Advan22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2010, 12:06 AM
  5. Speed Daddy Headers
    By Vioarr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2010, 03:29 PM
