Thread: SD Headers installed and A+++++
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 101
  1. #1 SD Headers installed and A+++++
    MA
    So I did the install with not many issues at all. I made sure all pipes fit prior to install and also made sure I had everything I needed to finish the job right. I did have to lower the subfreame and I also removed the MAP sensor and bracket too. This made it so easy to slide it in. I sealed all the joints with copper RTV and I have no leaks as of yet. I started around 1:30 and finished with clean up and shutting down the garage by 9:30. I also had to extend the front O2 and hammer the hell out of the tunnel for it to clear. All in all they came out great and I am very happy with the fitment. They sound so amazing too, what a huge diffrence over the manifolds. Thanks for all the input too guys, its really helpfull to be on these many great boards and do the research first. Now time too upload my new tune and Ill be ready for NED on the 25th. Here are a few pics foir everyone.
  2. #2 Re: SD Headers installed and A+++++
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    Good job. Still hate that dang down pipe! haha...
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  3. #3 Re: SD Headers installed and A+++++
    question time.... why in the hell do you still have your engine cover and why did you have to lower the subframe? : \
  4. #4 Re: SD Headers installed and A+++++
    Outer Space
    Great camera pics.
    02 GTP 13.6 @ 100mph - SOLD
  5. #5 Re: SD Headers installed and A+++++
    a few things...
    1) I'm actually digging the engine cover on some cars...it all depends
    2) Yay red RTV...and I thought I was the only one LOL
    3) Get rid of all of those misc. bullsh1t brackets (ex...one behind the coil pack, 2nd to the left of the right dogbone, and third by plug wire #2 and #4...then again...you might want to keep that one since you have a engine cover)
    4) Its way easier to yank the fans and ratchet strap the motor forward than to lower the subframe...just a FYI
  6. #6 Re: SD Headers installed and A+++++
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Where did you purchase your clamps to hold the pipes together from?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  7. #7 Re: SD Headers installed and A+++++
    love it. I cant wait to do mine.
    Are running it with no cat??
  8. #8 Re: SD Headers installed and A+++++
    Donating Users
    South Deerfield, MA
    Nice work!
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  9. #9 Re: SD Headers installed and A+++++
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    you can get them from napa for $13.
    Stainless too.
  10. #10 Re: SD Headers installed and A+++++
    oklahoma
    Wow looks great how is the performance with them on now?
  11. #11 Re: SD Headers installed and A+++++
    MA
    Thanks for all the compliments, I personally like the look with the engine cover on, the subframe was easy to lower in the back, took 5 seconds to do with air gun and I lowered it just enough to sneeek the rear header by. The clamps are from NAPA, my buddy got them too me for 9 each. I do not have a cat in there and have no plans of installing one either. The gains were noticable for sure, I also noticed a huge diffrence in the response and also how much faster it revs out. I couldnt be happier with them. Sounds so much better too. It actually reduced the exhaust drone I had quite a bit.
  12. #12 Re: SD Headers installed and A+++++
    Nov 2009
    Grand haven
    NOPE NO cat.
  13. #13 Re: SD Headers installed and A+++++
    Bowie, MD
    Lucky you dont have emissions. I have to have it every 2 years here in MD so im a little skeptical on what to do when i install my speed daddy headers.
  14. #14 Re: SD Headers installed and A+++++
    So...just go buy a fake cat from Frozen Boost...its a old converter casing with a straight pipe ran through it...so when welded in your exhaust it looks like it has a cat...done.
  15. #15 Re: SD Headers installed and A+++++
    Or if you have a tailpipe test then get a magnaflow 99009HM cat.
    You can pass with that cat and no EGR in ontario.
  16. #16 Re: SD Headers installed and A+++++
    MA
    Mass. has some of the stricest emmissions test in the country actually. But I used to runa wholesale autoparts store in the area and know all the shops and have pull at everyone of them. Plus with the HPtuners software I will remove all codes from the system so they never even scan. Problem solved.
  17. #17 Re: SD Headers installed and A+++++
    If they dont do a tailpipe test then your emissions standards are laughable.
  18. #18 Re: SD Headers installed and A+++++
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Maryland just does the obd2 scan. I passed with no cat FWIW
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  19. #19 Re: SD Headers installed and A+++++
    SE Level Member quadracer960's Avatar
    indiana
    Hey nice pictures and you have given me the confidence to buy s.d. headers and install them by myself, but i have heard there are 2 different types to buy, one fitting better. How would i tell the difference? Also, what looks to be the difference between the once that cost like $205 and the other ones costing around $185? I typed in gtp headers and they showed up. Thanks.
  20. #20 Re: SD Headers installed and A+++++
    MA
    they do tail pipe tests here, every year, like they guy said MA is bad when it comes to emissions.
    to op, i didnt realise you were on here to.
    SMGPFC Member #9
  1. Headers installed and temps under hood
    By Silver GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2010, 04:40 PM
  2. Speed daddy headers installed.
    By EricGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 03:45 PM
  3. headers installed
    By boostedcompg in forum General Tech Discussion
    Last Post: 12-19-2009, 03:24 AM
  4. ZZP Headers installed!
    By Reptile in forum General Tech Discussion
    Last Post: 03-10-2009, 11:11 AM
  5. Got my car back today had slp headers installed
    Last Post: 07-06-2008, 11:25 PM
