Thread: ses codes and car cutting out
Results 1 to 3 of 3
  1. #1 ses codes and car cutting out
    SE Level Member Xhondaguy's Avatar
    May 2008
    chicagoland
    ok so ive been struggling with this problem for a few days now and its getting quite annoying. When im driving down the road somethime my car will sputter , it doesnt matter if im giving it throttle or not it just sputters and sometimes it will die while sputtering. Evertime i get time to look at it i let my car sit there and idle and it wont do it, so naturally i cleared the codes and drove my car around for a while until it did it again, i scanned it and came up with a p0401 and p0107, the 107 is a code that ive had the whole time which i think is because of my intake so im not worried about that one, but the 401 is a egr code, my question is would the egr cause the car to die like that it is an intermittent problem, and wouldnt a stuck open egr cause it to run bad all the time? anyways please help i thought that you guys might have some good ideas
  2. #2 Re: ses codes and car cutting out
    Hoffman/Schaumburg, IL
    I would suggest to never just ignore a code,
    p0107 = map fault
    That could cause your egr code, cause the pcm uses the map to check the egr,
    If you have a GTP:
    Find the vacuum hose you knocked off the map sensor and you should be good
    If you have a GT:
    Make sure he map is pluged in and clean
  3. #3 Re: ses codes and car cutting out
    May 2008
    chicagoland
    hey thanks for the help, but i fixed it, i used the good old GM tap test to force the problem and it turns out it was the maf sensor it nice having no codes and a smooth running car again, O and $120 out of my wallet
  1. OBDII Codes [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-26-2011, 01:23 AM
  2. ecu codes ??
    By sal3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2008, 12:48 PM
  3. Car Cutting out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-31-2008, 04:48 PM
  4. Paint Codes
    By thermanlee in forum Visual/Body Modifications
    Last Post: 01-14-2008, 11:39 PM
  5. OBD2 codes
    By sra_chipmunk in forum Forum Bugs/Suggestions
    Last Post: 01-14-2008, 12:56 AM
