About 5 months ago driving home from work my car cut off on me. Had it towed home, ended up the TB gasket failed and sucked coolant into the engine.
Fast forward 5 months and it cut off again. Had it towed home and took another car into work. I have yet to look into it. It was smoking white smoke bad. It cranks won't fire just like last time.
Last time to fix it i swapped gaskets, pulled plugs cranked it sprayed the coolant out of the cylinders and let them air dry for a bit. New AP104s and cranked it up let it idel and smoked like crazy for a bit. It ran fine after that.
I am running a TB spacer with 50/50 methanol water injection. Would that have anything to do with it?
Is this a regular thing with these cars/engines?
Thanks.
