Thread: coolant elbows
Results 1 to 14 of 14
  1. #1 coolant elbows
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    do any l67s only utilize one coolant elbow like my 97 l36 does? if so what years?
  2. #2 Re: coolant elbows
    Outer Space
    L67's have two elbows... mine is an 02.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: coolant elbows
    depends on the tensioner bracket thats on there i guess.
    I always thought they all had two.
    I can tell you 99+ will for sure have two regardless of which engine it was.
  4. #4 Re: coolant elbows
    Donating Users kfish's Avatar
    Ohio
    my 98 has one elbow.
  5. #5 Re: coolant elbows
    Nov 2009
    Grand haven
    97 and 98 had one plastic and one alum one with an oring on it.
  6. #6 Re: coolant elbows
    Michigan
    kfish are you running a l36 or l67?
  7. #7 Re: coolant elbows
    top swap
  8. #8 Re: coolant elbows
    Pick up Dorman 47065 for the two elbows and you'll either use one elbow and the large o-ring off the second or both elbows. Etiher way..you'll want to spend the $4 to get both.
  9. #9 Re: coolant elbows
    Michigan
    what would i have to do differently in order to top swap? what kind of LIM would i need?
  10. #10 Re: coolant elbows
    read the top swap thread.
  11. #11 Re: coolant elbows
    Michigan
    dude, that's not what i'm asking. since all other motors use 2 coolant elbows, i'm asking if this would change anything up from a normal top swap.
    i've read that **** plenty of times.
  12. #12 Re: coolant elbows
    You're going to be using the same alternator bracket as the one you have unless you want to get a newer one so it'll be the same as for whatever alternator bracket you use.
  13. #13 Re: coolant elbows
    Michigan
    you're saying the lim and alt. bracket need to match?
  14. #14 Re: coolant elbows
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    97/98 1 elbow 99+ 2 elobows
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  1. How do you replace the coolant elbows?
    By Mercenary in forum General Tech Discussion
    Last Post: 07-19-2010, 06:50 PM
  2. Corrosion on new timing sets? Plus advice on coolant elbows, LIM, AC, waterpump, etc
    By Scott Kane in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2010, 04:13 AM
  3. Coolant elbows
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 12-01-2009, 11:58 AM
  4. Coolant Elbows for 2000 GTP
    By nickbuol in forum General Tech Discussion
    Last Post: 07-21-2009, 10:51 PM
  5. Replacing uim and lim 97 gp 3.8 (Coolant Elbows?)
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2008, 05:27 PM
