I found that there is no fuel pressure at the rail, so i checked voltage to the pump and i'm only getting 5 volts. First question should there be 12 volts ( the battery is fully charged). I replaced both relays and the fuse. I tried the high speed pump trick and i'm still getting 5 volts on the same wire on the connector. There isn't any check engine lights on, the secrurity lights isn't flashing. At first i thought it was the fuel pump but not now that im only getting 5 volts to the pump. Any suggestions would be great, thanks.
